Page 7 of 8 1 2 3 4 5 6 7 8
Re: Thermoquad vs. Six Pack/Six Barrel. Which is best ? [Re: dOrk !] #779692
09/19/10 12:37 AM
09/19/10 12:37 AM
Desert Tracker
HYPER8oSoNic Offline OP
Desert Tracker
Ferrr yurr viewing enjoyment .....
SEE how happy this HEMI is .... with a pair of Plastic-Fantastics on it ? ....
(I was cleaning-out my desktop and found this pic)
Doc, that is a MEAN set of T-Q's on that HEMI!!
Is that car a low 11-high ten second piece!!
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: Thermoquad vs. Six Pack/Six Barrel. Which is best ? [Re: quick77rt ] #779693
09/19/10 12:44 AM
09/19/10 12:44 AM
Desert Tracker
Desert Tracker
Makes an EVEN BETTER sound opening up thru the gears!! Even better when the doors slap shut...Huh???
So a T quad closes between shifts?....instead of how nice they sound running, or letting off with the doors slapping shut, how about a pic with sound=vid??? vs a pic with comments???
Try one on your motor and have firsthand witness!!
No YouTube or magazine link. You will
feel what it does and how well it runs!!
Re: Thermoquad vs. Six Pack/Six Barrel. Which is best ? [Re: quickd100] #779694
09/19/10 12:49 AM
09/19/10 12:49 AM
Desert Tracker
Desert Tracker
That's an old picture from under the hood of my wreck. Since that was taken I now have 2 140gph pumps, 1/2" fuel line all the way to the regulator, very large inline filter. The carbs will flow 900cfm+ each. The whole shoot'n match will be going on my dyno this winter for some tweaking.
It really runs nice on the street with this setup. Acceptable mileage and enough power to smoke the tires at 60-70 mph. Dave
Good setup Dave. Love the multiple carbs, even
better since they aren't Holleys. Definitely
something different!!
Re: Thermoquad vs. Six Pack/Six Barrel. Which is best ? [Re: HYPER8oSoNic] #779695
10/17/10 04:03 PM
10/17/10 04:03 PM
Desert Tracker
Desert Tracker
What would be more advantageous on a hi-riser (tunnel ram) two TQ's, two 660's or a FLOWED
six pack setup (old weiand or EDDY str hi-rise)?
We are talking hi-end bracket motors, small OR big
block (12.0-hi 10's).
Re: Thermoquad vs. Six Pack/Six Barrel. Which is best ? [Re: HYPER8oSoNic] #779696
10/17/10 05:14 PM
10/17/10 05:14 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Just thinking about this makes me feel like I'm cheating
Re: Thermoquad vs. Six Pack/Six Barrel. Which is best ? [Re: ScottSmith_Harms] #779697
10/17/10 05:30 PM
10/17/10 05:30 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Is the 340 six pack still the one to beat in F.A.S.T. i thought a t-quad 340 ran a 11.45?
Re: Thermoquad vs. Six Pack/Six Barrel. Which is best ? [Re: ScottSmith_Harms] #779698
10/17/10 08:55 PM
10/17/10 08:55 PM
nielsville, minn.
Q
quickd100 Online content
quickd100  Online Content
Q
nielsville, minn.
Scott, I LIKE!
Re: Thermoquad vs. Six Pack/Six Barrel. Which is best ? [Re: ScottSmith_Harms] #779699
10/17/10 11:36 PM
10/17/10 11:36 PM
Desert Tracker
Desert Tracker
Anyone have a spare napkin or handkerchiff?
Re: Thermoquad vs. Six Pack/Six Barrel. Which is best ? [Re: quickd100] #779700
10/17/10 11:39 PM
10/17/10 11:39 PM
Iowa USA
Cuda54 Offline
Cuda54  Offline
Iowa USA
Let see what will come back out? We will take the 3 holley two barrels a qj into a bucket of carb cleaner. We will keep them in there for a day or so. Then we will put them back on and start them up. Then we will see who has a carb. I love my 3 holleys on my 525hp 440 auto in my 1972 Cuda.
Re: Thermoquad vs. Six Pack/Six Barrel. Which is best ? [Re: Cuda54] #779701
10/18/10 12:10 AM
10/18/10 12:10 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Carb cleaner disolves Quadrajets? News to me
Re: Thermoquad vs. Six Pack/Six Barrel. Which is best ? [Re: Cuda54] #779702
10/18/10 01:13 AM
10/18/10 01:13 AM
Desert Tracker
Desert Tracker
QJ? Mopar engine?
3 Holleys (six pack)? Mopar engine?
TQ? Mopar engine?
Re: Thermoquad vs. Six Pack/Six Barrel. Which is best ? [Re: ScottSmith_Harms] #779703
10/18/10 10:30 PM
10/18/10 10:30 PM
moparx Offline
moparx  Offline
scott, are you thinking of using adapter plates, or hogging out the manifold plenums to run the thermoquads ?
Re: Thermoquad vs. Six Pack/Six Barrel. Which is best ? [Re: moparx] #779704
10/18/10 10:52 PM
10/18/10 10:52 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Adapters, no way I'd hack on those Short Rams
Re: Thermoquad vs. Six Pack/Six Barrel. Which is best ? [Re: ScottSmith_Harms] #779705
10/18/10 11:00 PM
10/18/10 11:00 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
SHORT rams ? ... .... show me some LONGer ones than that !!
And BTW ... I worked at a shop that had some trick salvage Mopar parts before I went into the service .....
They used those intakes to hold TARPS down on the outside !! They probably had THREE HUNDRED of those
Re: Thermoquad vs. Six Pack/Six Barrel. Which is best ? [Re: dOrk !] #779706
10/18/10 11:04 PM
10/18/10 11:04 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Just for you Doc
Re: Thermoquad vs. Six Pack/Six Barrel. Which is best ? [Re: ScottSmith_Harms] #779707
10/18/10 11:10 PM
10/18/10 11:10 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
And of course, the "Shortest" Short Ram.
Re: Thermoquad vs. Six Pack/Six Barrel. Which is best ? [Re: ScottSmith_Harms] #779708
10/18/10 11:14 PM
10/18/10 11:14 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Shortest that is unless you count aftermarket and small blocks
Re: Thermoquad vs. Six Pack/Six Barrel. Which is best ? [Re: ScottSmith_Harms] #779709
10/18/10 11:21 PM
10/18/10 11:21 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
Hay Scott .... I see some diffs in them ... but WHY the diff castings ? ... and what IS the length diff ...if any?
Re: Thermoquad vs. Six Pack/Six Barrel. Which is best ? [Re: dOrk !] #779710
10/19/10 12:25 AM
10/19/10 12:25 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Doc the runner lengths are the same but the DIVIDING WALL between them only goes about halfway down on the Short Rams, so, short wall = "Short Ram" full length (long) dividing wall = "Long Ram".
The shorter dividing wall effectively moves the peak torque about 1,000 rpms upward. Niether intake is a drag strip terror, but no slouch either with the right combo, real torque monsters even stock.
Stock Long Ram peak torque is at 2,800 rpm, the stock Short Ram is 3,800 rpm.
Of course if you want to have the king of all "Packs" you'll need a Navarro "Sixteen Pack"
Navarro Quad Quad Cross Ram for your viewing pleasure
Re: Thermoquad vs. Six Pack/Six Barrel. Which is best ? [Re: dOrk !] #779711
10/19/10 12:29 AM
10/19/10 12:29 AM
Desert Tracker
Desert Tracker
Doc, I do remember the LONG Ram was measured at
nearly 21" in length. The SHORT Ram was measured
almost the same in length. The LONG Ram was tuned for the 2500-3500rpm (peak torque) range, while the SHORT Ram was tuned for the 3500-4000rpm (peak
torque) range. A BIG difference the divider makes in power!! The Crossram, (SHORTY Ram) 15" in length, 5000-5500rpm (peak torque)
