lock up 727 vs non lockup interchange #779079
08/20/10 06:36 PM
08/20/10 06:36 PM
New Hampshire
n_bogie1984 Offline OP
New Hampshire
well 9i blew a driveshaft out and it wiped my sprag on my 69 long shaft non lockup tranny, now i have a 71 lockup tranny, can i take all of the guts out of the non and put them in the lockup case? the case and everything is the same right besides the imput shaft and pump? i know the valve bodys are diffrent but they are the same bolt in and ports right? so my full manual body will bolt into it?
any help would be great
Re: lock up 727 vs non lockup interchange [Re: n_bogie1984] #779080
08/20/10 07:19 PM
08/20/10 07:19 PM
Alone in the darkness
gamagoat6x6 Offline
super street
gamagoat6x6  Offline
super street
No lockups in `71.
`02 RAM2500 SPORT V10 4x4 `06 GMC sierra NO cars
Re: lock up 727 vs non lockup interchange [Re: gamagoat6x6] #779081
08/20/10 07:21 PM
08/20/10 07:21 PM
New Hampshire
New Hampshire
maybe it was a 78 i cant remember year but it has the smooth imput shaft tip, so i know its a lockup
Re: lock up 727 vs non lockup interchange [Re: n_bogie1984] #779082
08/20/10 09:25 PM
08/20/10 09:25 PM
New Hampshire
New Hampshire
any ideas got a show tomarrow so i kinda gotta try and get this going lol
Re: lock up 727 vs non lockup interchange [Re: n_bogie1984] #779083
08/21/10 02:43 AM
08/21/10 02:43 AM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
You can swap the '69 guts into the lockup case but don't mix parts, the lockup output shaft has different front planetary splines than the '69.
Re: lock up 727 vs non lockup interchange [Re: John_Kunkel] #779084
08/22/10 05:16 PM
08/22/10 05:16 PM
New Hampshire
New Hampshire
ended up getting lucky, got the non lockup tore down and it had cracked the front planitary gear from the center to each gear, and wiped out the teeth in the center, slammed another one i had kicking around in and seems of lol, show got rained out today so didnt get to really try it, but shocked it cracked and took teeth off it befor it broke the overrun or anyhting else
