Rear Speaker Installation Question #77854
06/21/08 02:21 PM
06/21/08 02:21 PM
Anonymous OP
Anonymous OP
Hello,
My '70 Challenger's rear speakers have been missing since I've owned the car. Now, I'd like to install a pair of 6"x9" speakers.
I have a package tray installed with speaker cutouts, but was wondering what type of fastener (metal screws or bolts?) is recommended to secure the speakers w/o puncturing through the package tray?
Thanks much for any info on how you guys have done this!
Re: Rear Speaker Installation Question #77855
06/21/08 02:25 PM
06/21/08 02:25 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
i took the package tray out and set the speakers through the hole, secured them from the top, then put the package tray over it. (you cannot see the speakers through the package tray)
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Rear Speaker Installation Question [Re: GoodysGotaCuda] #77856
06/21/08 02:28 PM
06/21/08 02:28 PM
stratford,ontario,canada
JD340 Offline
JD340  Offline
Might be a little more disassembly then you hoped for, but the cleanest way to do it.
Nothing to see here. Carry on.
Re: Rear Speaker Installation Question #77857
06/21/08 03:23 PM
06/21/08 03:23 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Before worrying about fasteners and screws..
You should check the height of the 6x9 speaker frame.
Often this can be higher than the pressed metal recess which can cause the package tray to be raised and not to sit down properly. Also if the speaker is a multi-driver such as a 2-way or 3-way again check the height of the mid/tweeter frame you do not want the package tray to rest directly on this or one can get vibrations..
In extreme cases we have mounted 6x9s from below the metal frame. Key point is you want the package tray to have some clearance between it and the speaker, or there will be vibrations and rattles..
Or even restricted speaker output.
Just my $0.02..
Re: Rear Speaker Installation Question [Re: Sinitro] #77858
06/21/08 03:53 PM
06/21/08 03:53 PM
Turneffe
BJohnson Offline
BJohnson  Offline
Turneffe
Factory speakers were installed from under the package tray with sheet metal screws.
Re: Rear Speaker Installation Question [Re: BJohnson] #77859
06/22/08 09:24 AM
06/22/08 09:24 AM
Anonymous OP
Anonymous OP
If installing from underneath, what size sheet metal screws were used? Are there any other fasteners needed to hold these screws in place or do they grip onto the metal frame if the right size?
Thanks!
Re: Rear Speaker Installation Question #77860
06/22/08 11:14 AM
06/22/08 11:14 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I fit in that way but using fasteners
Re: Rear Speaker Installation Question [Re: NachoRT74] #77861
06/22/08 10:09 PM
06/22/08 10:09 PM
Anonymous OP
Anonymous OP
What type of fastener is used for this ? Thanks!
Re: Rear Speaker Installation Question #77862
06/22/08 10:18 PM
06/22/08 10:18 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
I've used fasteners that look like small C nuts. you know.....the things the fender bolts tighten up into?
Re: Rear Speaker Installation Question #77863
06/23/08 12:59 AM
06/23/08 12:59 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
something like this:
several kind of fasteners with same purpouse, doesnt need to be exactly this one. I simply used some I had around from cars I parted out.
This one is specifically called U nut.
then there are C nuts and J nuts, last one mostly used for Body panels
Re: Rear Speaker Installation Question [Re: NachoRT74] #77864
06/23/08 10:59 AM
06/23/08 10:59 AM
None
71rm23 Offline
71rm23  Offline
None
That will work!
