Rear Speaker Installation Question
#77854
06/21/08 02:21 PM
06/21/08 02:21 PM
Hello, My '70 Challenger's rear speakers have been missing since I've owned the car. Now, I'd like to install a pair of 6"x9" speakers.
I have a package tray installed with speaker cutouts, but was wondering what type of fastener (metal screws or bolts?) is recommended to secure the speakers w/o puncturing through the package tray?
Thanks much for any info on how you guys have done this!
Re: Rear Speaker Installation Question
#77857
06/21/08 03:23 PM
06/21/08 03:23 PM
Posts: 5,439 So Cal
Sinitro
So Cal
Before worrying about fasteners and screws.. You should check the height of the 6x9 speaker frame. Often this can be higher than the pressed metal recess which can cause the package tray to be raised and not to sit down properly. Also if the speaker is a multi-driver such as a 2-way or 3-way again check the height of the mid/tweeter frame you do not want the package tray to rest directly on this or one can get vibrations.. In extreme cases we have mounted 6x9s from below the metal frame. Key point is you want the package tray to have some clearance between it and the speaker, or there will be vibrations and rattles.. Or even restricted speaker output. Just my $0.02..
[Re: BJohnson]
#77859
06/22/08 09:24 AM
06/22/08 09:24 AM
If installing from underneath, what size sheet metal screws were used? Are there any other fasteners needed to hold these screws in place or do they grip onto the metal frame if the right size?
Thanks!
#77860
06/22/08 11:14 AM
06/22/08 11:14 AM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
I fit in that way but using fasteners
[Re: NachoRT74]
#77861
06/22/08 10:09 PM
06/22/08 10:09 PM
What type of fastener is used for this ? Thanks!
[Re: NachoRT74]
#77864
06/23/08 10:59 AM
06/23/08 10:59 AM
Posts: 2,592 None
71rm23
None
something like this:
several kind of fasteners with same purpouse, doesnt need to be exactly this one. I simply used some I had around from cars I parted out.
This one is specifically called U nut.
then there are C nuts and J nuts, last one mostly used for Body panels
That will work!
