Re: K1 Crank / Rods and Diamond pistons
[Re: GregCon]
#778485
08/19/10 08:17 PM
08/19/10 08:17 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
What is Dram?
I don't trust anyone in Houston to assemble a Hemi without screwing it up. No one I am aware of, anyway.
That is member Performance Only , Dan , he's in West Palm, Fl.
[Re: GregCon]
#778490
08/19/10 10:19 PM
08/19/10 10:19 PM
Posts: 2,091 Delray beach, Florida
Performance Only
If a guy (me) wanted a Hemi short block machined and assembled using K1 and Diamond parts, is there any shop in particular who could do this relatively quickly and without screwing it up? I have the block, they would need to vend the other parts to me in addition to the work.
Give me a call if you'd like to talk about your needs. we can supply any parts, machine work and assembly necessary. we also have some specials going on you'll likely be very interested in. 561-758-6604 all of our block work is done on our 4 axis CNC machining center along with our Rottler HP-6 diamond cylinder honing machine. we have full in house machining capabilities. you can check with the guy's above that recommended me if you need any references.
by the way, so i don't single one of you guys out, if you happen to be waiting on your complete engine, it should be at your place monday or tuesday according to the trucking company. thank you for your business.
machine shop owner and engine builder
