K1 Crank / Rods and Diamond pistons #778481
08/19/10 06:19 PM
08/19/10 06:19 PM
Houston TX
GregCon Offline OP
GregCon  Offline OP
Houston TX
If a guy (me) wanted a Hemi short block machined and assembled using K1 and Diamond parts, is there any shop in particular who could do this relatively quickly and without screwing it up? I have the block, they would need to vend the other parts to me in addition to the work.
Re: K1 Crank / Rods and Diamond pistons [Re: GregCon] #778482
08/19/10 06:30 PM
08/19/10 06:30 PM
Mo.
supercomp Offline
supercomp  Offline
Mo.
Dram, we just got those exact parts for a low deck 511 wedge.
Re: K1 Crank / Rods and Diamond pistons [Re: GregCon] #778483
08/19/10 07:04 PM
08/19/10 07:04 PM
AndyF Offline
AndyF  Offline
Most anyone who builds high performance engines should be able to handle that work for you. Should be plenty of local shops who can do that for you.
Re: K1 Crank / Rods and Diamond pistons [Re: AndyF] #778484
08/19/10 07:26 PM
08/19/10 07:26 PM
Houston TX
GregCon Offline OP
GregCon  Offline OP
Houston TX
What is Dram?
I don't trust anyone in Houston to assemble a Hemi without screwing it up. No one I am aware of, anyway.
Re: K1 Crank / Rods and Diamond pistons [Re: GregCon] #778485
08/19/10 08:17 PM
08/19/10 08:17 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What is Dram?
That is member Performance Only , Dan , he's in West Palm, Fl.
Re: K1 Crank / Rods and Diamond pistons [Re: GregCon] #778486
08/19/10 08:30 PM
08/19/10 08:30 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
There have to be LOTS of shops in and around the Houston area ..
One that comes to mind is the Nickens Bros. They have raced some big-time fast cars ...and once had a Mopar Pro Stock big$$$ sponsor deal.
Re: K1 Crank / Rods and Diamond pistons [Re: dOc !] #778487
08/19/10 08:32 PM
08/19/10 08:32 PM
s e mich
ro23car Offline
ro23car  Offline
s e mich
jeff at mch macomb mich.
Re: K1 Crank / Rods and Diamond pistons [Re: ro23car] #778488
08/19/10 08:56 PM
08/19/10 08:56 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
Dan at Performance only Racing he is in FL and a member on here
Re: K1 Crank / Rods and Diamond pistons [Re: Scamp408] #778489
08/19/10 10:14 PM
08/19/10 10:14 PM
Houston TX
GregCon Offline OP
GregCon  Offline OP
Houston TX
I've been down the road with Nickens...aside from being Chevy guys they did their share of screwing up my stuff.
Re: K1 Crank / Rods and Diamond pistons [Re: GregCon] #778490
08/19/10 10:19 PM
08/19/10 10:19 PM
Delray beach, Florida
P
Performance Only Offline
P
Give me a call if you'd like to talk about your needs. we can supply any parts, machine work and assembly necessary. we also have some specials going on you'll likely be very interested in.
561-758-6604
all of our block work is done on our 4 axis CNC machining center along with our Rottler HP-6 diamond cylinder honing machine. we have full in house machining capabilities.
you can check with the guy's above that recommended me if you need any references.
by the way, so i don't single one of you guys out, if you happen to be waiting on your complete engine, it should be at your place monday or tuesday according to the trucking company. thank you for your business.
machine shop owner and engine builder
Re: K1 Crank / Rods and Diamond pistons [Re: Performance Only] #778491
08/19/10 10:56 PM
08/19/10 10:56 PM
Houston TX
GregCon Offline OP
GregCon  Offline OP
Houston TX
OK will do.
