To my fellow Canadian friends in Ontario..... #777972
08/19/10 09:53 AM
08/19/10 09:53 AM
Woodbridge
Tommy The Chryco Offline OP
Woodbridge
Who do you use to strip your rusted parts?
Techno strip is far too expensive and they really don't care about that or customer service nor for that matter repeat business.
So....I would rather not use them at all.
Does anyone have another service supplier????
Feedback is welcome on your opinion of techno strip...
Fight the Good Fight- Elastomeric Bumpers and The Better "Shaker kits"
Re: To my fellow Canadian friends in Ontario..... [Re: Tommy The Chryco] #777973
08/19/10 10:12 AM
08/19/10 10:12 AM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
I think Techno Strip is only only game in town these days?
I held off using them forever until just recently.
I would have to say that the quality of the stripping was first rate.
I agree their prices are high and they seem to get higher every time.
But if you factor in the time savings and how messy a job like stripping a fender can be, then it's easy to justify their pricing.
I'm also curious to see if there's another place local to us
CHECK OUT MY NEW WEB SITE !
Re: To my fellow Canadian friends in Ontario..... [Re: anlauto] #777974
08/19/10 10:44 AM
08/19/10 10:44 AM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
techno strip is a caustic chemical dipper i assume?
just media blast it, you wont have chemicals that you cant get to stuck in the seams
here is a cuda fender that was dipped then primered (redi-strip in BC did this one)
Re: To my fellow Canadian friends in Ontario..... [Re: chrisf] #777975
08/19/10 10:45 AM
08/19/10 10:45 AM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
same fender
Re: To my fellow Canadian friends in Ontario..... [Re: chrisf] #777976
08/20/10 10:26 PM
08/20/10 10:26 PM
Caledon, Ontario
smac77 Offline
smac77  Offline
Caledon, Ontario
I've seen a few cars that have been dipped bleeding out like this one, although not nearly as bad... looks like that fender was never washed out properly. Some of the us dippers have an e coat dip as well as a third step after the wash that is supposed to be much better at preventing this... so I've heard???
I media blast, then hand strip the large unsupported panels
If you're set on it... I thought there was another place out towards oakville doing it as well... not sure of the name though
Restoration, Sales and Canadian Distributor For:
AMD Sheetmetal
Wizzard Direct Fit, Bolt In Aluminum Radiators
Legendary Interiors
SSBC & Wilwood Brakes
Control Freak Suspensions
Fine lines Tubing
and many more...
www.macleanclassics.com
Re: To my fellow Canadian friends in Ontario..... [Re: smac77] #777977
08/20/10 11:39 PM
08/20/10 11:39 PM
Ont, Canada
moparo Offline
moparo  Offline
Ont, Canada
I have been going to Techno Strip Club for a long time.
I can show restos which are 10 years old that were stripped. No issues, just because it looks clean means noting there is a lot of additional cleaning to be done to ensure that bleeding does not happen.
Yes they are pricey.
performancecarrestorations.com
Re: To my fellow Canadian friends in Ontario..... [Re: smac77] #777978
08/21/10 12:09 AM
08/21/10 12:09 AM
canada
mridolfo Offline
mridolfo  Offline
canada
I had my car stripped at Technostrip last April I made sure I was there when it was taken out of the tank and made sure it was rinsed extra good. I had them working on it for almost 2 hours.
Cars in primer now and no signs of bleeding acid.
Re: To my fellow Canadian friends in Ontario..... [Re: Tommy The Chryco] #777979
08/21/10 12:13 AM
08/21/10 12:13 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I wouldn't buy an acid dipped piece (and certainly not a car) unless it was neutralized and then dipped in EDP primer.
Sheldon
Re: To my fellow Canadian friends in Ontario..... [Re: mridolfo] #777980
08/21/10 12:26 AM
08/21/10 12:26 AM
Caledon, Ontario
smac77 Offline
smac77  Offline
Caledon, Ontario
Technostrip did destroy a glass/plastic nose once on a buddies firebird... they claimed they could strip it without damage... they were wrong...
AMD Sheetmetal
Legendary Interiors
Fine lines Tubing
and many more...
Re: To my fellow Canadian friends in Ontario..... [Re: smac77] #777981
08/22/10 08:21 PM
08/22/10 08:21 PM
Woodbridge
Woodbridge
So gentlemen is there an alternative.... besides these thiefs!!!
Re: To my fellow Canadian friends in Ontario..... [Re: Tommy The Chryco] #777982
08/22/10 08:45 PM
08/22/10 08:45 PM
Toronto (YYZ) Ontario
YYZ Offline
YYZ  Offline
I would look into the place in Detroit that does the alkaline stripping and E-coating afterwards.
(sorry, I don't recall the name of the place, but I should have one of their flyers around here somewhere).
Re: To my fellow Canadian friends in Ontario..... [Re: YYZ] #777983
08/23/10 11:34 PM
08/23/10 11:34 PM
Caledon, Ontario
smac77 Offline
smac77  Offline
Caledon, Ontario
I finnally remembered it !!! it's in brantford.
Greenwich Metal Cleaning Services Inc
347 Greenwich St. Building 16 (map)
P.O. Box 574
Brantford, Ontario
N3T 5N9 Canada
Phone: (519) 758-9897
Fax: (519) 758-5116
AMD Sheetmetal
Legendary Interiors
Fine lines Tubing
and many more...
Re: To my fellow Canadian friends in Ontario..... [Re: smac77] #777984
08/24/10 12:42 AM
08/24/10 12:42 AM
Brantford Ontario
69_SIX_PACK Offline
69_SIX_PACK  Offline
Brantford Ontario
P.O. Box 574
Brantford, Ontario
N3T 5N9 Canada
Fax: (519) 758-5116
That place has been closed for well over a year now.
Re: To my fellow Canadian friends in Ontario..... [Re: 69_SIX_PACK] #777985
08/24/10 12:49 AM
08/24/10 12:49 AM
Toronto, ON
ehbody Offline
ehbody  Offline
Toronto, ON
Shoot, that was the one I was thinking of too use.
Shawn 70 AAR
Re: To my fellow Canadian friends in Ontario..... [Re: ehbody] #777986
08/24/10 09:42 AM
08/24/10 09:42 AM
Tecumseh, Ontario, Canada
Moparnut Offline
Moparnut  Offline
I think there is a place in Chatham. I have a few calls out to get the name.
Re: To my fellow Canadian friends in Ontario..... [Re: 69_SIX_PACK] #777987
08/25/10 12:39 AM
08/25/10 12:39 AM
Caledon, Ontario
smac77 Offline
smac77  Offline
Caledon, Ontario
P.O. Box 574
Brantford, Ontario
N3T 5N9 Canada
Fax: (519) 758-5116
oh well , I tried.... they're still up on the internet in one of the business directories
AMD Sheetmetal
Legendary Interiors
Fine lines Tubing
and many more...
Re: To my fellow Canadian friends in Ontario..... [Re: smac77] #777988
08/25/10 10:40 PM
08/25/10 10:40 PM
canada
mridolfo Offline
mridolfo  Offline
canada
Hetworth AKA Team Reclamation in Cambridge strips. Not sure if they do car bodies.
