Lost spark #777002
08/18/10 09:58 PM
08/18/10 09:58 PM
Springfield,Or
belvendere Offline OP
Springfield,Or
I'm puting a 408 stroker in my belvedere..motor was running good until my zbar smacked my positive battery cable while car was off..noticed negative battery cable melting..since then I have no spark..the car has electronic ignition I tried a new coil and ignition box still no spark..did I fry something out? Thanks
67 Belvedere
69 Dart Custom
65 Dart GT 273/904
Re: Lost spark [Re: belvendere] #777003
08/18/10 11:55 PM
08/18/10 11:55 PM
take off the yellow "ign" wire off of the starter relay to disable the starter. turn ign sw to "on" & check for voltage at the ballast/coil positive primary/"point" of the ECU pentastar connector (assuming 4 pin ECU/2 terminal ballast). Have a helper hold the key to "start" & recheck the above.
Re: Lost spark [Re: RapidRobert] #777004
08/19/10 09:41 PM
08/19/10 09:41 PM
Springfield,Or
Springfield,Or
Yes it is a 4 prong plug.. I'm getting power to where needed..still not getting spark from coil thanks for your help
67 Belvedere
69 Dart Custom
65 Dart GT 273/904
Re: Lost spark [Re: belvendere] #777005
08/19/10 09:58 PM
08/19/10 09:58 PM
take off the wire from the coil negative primary terminal & w a jumper wire w alligator clips on each end ground the negative primary terminal (not the wire you removed from the terminal) to ground repeatedly like Morse Code and w the coil secondary wire (the dist end) held 1/4" from ground see if it will spark as you make/break contact (ign on) w your jumper wire. This tells you the coil/ballast/ign sw and their attending wiring is OK and leaves the ECU and the dist pickup (& their attending wiring) as the culprit. The above could perform OK when cool and act up when hot but you should see something. Holler back.
Re: Lost spark [Re: belvendere] #777006
08/19/10 10:32 PM
08/19/10 10:32 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Have U checked the fusible link @ the bulkhead connector?
Re: Lost spark [Re: RapidRobert] #777007
08/20/10 09:11 PM
08/20/10 09:11 PM
Springfield,Or
Springfield,Or
I am not exactly sure what you mean by coil secondary wire. A side note i tried a different dist. Three ignition boxes and 3 coils 3 ballast resistors some old some brand new.
67 Belvedere
69 Dart Custom
65 Dart GT 273/904
Re: Lost spark [Re: belvendere] #777008
08/20/10 09:36 PM
08/20/10 09:36 PM
The wire from the coil center terminal to the dist center terminal.
Re: Lost spark [Re: RapidRobert] #777009
08/21/10 11:08 AM
08/21/10 11:08 AM
hobbs, new mexico
SixDRacing Offline
SixDRacing  Offline
hobbs, new mexico
do you have a groung from engine to frame, frame to battery, and battery to engine?
if all grounds are good and installed correctly and large enough cable, the positive cable should had been the one to melt when shorted, not the negative.
Re: Lost spark [Re: belvendere] #777010
08/23/10 04:38 AM
08/23/10 04:38 AM
Oregon USA
Jeff008belvedere Offline
Oregon USA
we gotta figure this out so your car can stop living at my house. sounds like we need to start by grounding the hell out of it.
1966 belvedere Sedan (post)slanter auto :-( 1967 GTX 440/727 1964 barracuda 318/auto
