dirt in paint #776858
08/18/10 06:49 PM
08/18/10 06:49 PM
OH
junkyardmaxie Offline OP
Happy Birthday junkyardmaxie  Offline OP
OH
PAINTERS PLEASE
got some dirt in my paint job. on tops of front fenders and front header panel.can i wet sand with 2000 paper,and then buff? what would be the right thing to do, to get the dirt out without messing up the paint. BACK YARD PAINTER THANKS
Re: dirt in paint [Re: junkyardmaxie] #776859
08/18/10 08:14 PM
08/18/10 08:14 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
what type of paint
Re: dirt in paint [Re: 05dakota] #776860
08/18/10 09:59 PM
08/18/10 09:59 PM
OH
OH
nason single stage red
Re: dirt in paint [Re: junkyardmaxie] #776861
08/18/10 10:21 PM
08/18/10 10:21 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Yes. You may want to start with soemthing more like 1000 grit if the "dirt" requires, then graduate to 1500/2000+ then buff. Buff with a foam pad, not wool.
No problem. You may be so pleased with results you decide to cut & buff more than you thought!!!
Re: dirt in paint [Re: junkyardmaxie] #776862
08/19/10 09:05 AM
08/19/10 09:05 AM
Jacksonville Florida
elitecustombody Offline
I'd invest in a Steck dirt nibbler/file, most paint stores have them in stock, once they are cut down, use 1200 grit on firm block,followed by 1500, usually single stage paint responds very well even to 1200 grit scratches,no need to go past 1500.Just be careful not to sand or buff through
