Wiring rev counter to Msd #775973
08/17/10 06:33 PM
08/17/10 06:33 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
Is a tacho more accurate through the msd than off the coil.
I have bought an old altometer playback recorder, I just wondered if anyone had used one and how they rated it.
Mick
Re: Wiring rev counter to Msd [Re: deaks] #775974
08/17/10 06:48 PM
08/17/10 06:48 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
If you are using an MSD box to fire the ignition, you use the tach output on it, do not connect the tach to the coil.
Re: Wiring rev counter to Msd [Re: OzHemi] #775975
08/17/10 06:53 PM
08/17/10 06:53 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
It was connected that way before i got the msd but i'm going to change it because i want to use the playback recorder.
Mick
Re: Wiring rev counter to Msd [Re: deaks] #775976
08/18/10 02:51 PM
08/18/10 02:51 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Hi Mike.
I used to have it connected to the coil and left that way when I first swiched over to a 6AL. The tach read high at low revs and it would go down when you revved up Extreme example I know, it was the multiple coil pulse doing it. Switched to MSD tach o/p and OK.
Re: Wiring rev counter to Msd [Re: Tig] #775977
08/18/10 07:09 PM
08/18/10 07:09 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
So switching to the msd output improved it.
Thanks Mick
Re: Wiring rev counter to Msd [Re: deaks] #775978
08/18/10 08:01 PM
08/18/10 08:01 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Yes, no problems after that.
