What is the rod on back of TF727? #775506
08/16/10 10:20 PM
08/16/10 10:20 PM
Chillicothe, Ohio
Groundhawg Offline OP
Chillicothe, Ohio
Hi. I've got a TF727 transmission in an '87 Dodge 4x4 and it's leaking from a rod that is located right below the tailshaft on the back. The rod is flush with the casing and is right above the tranny pan. It moves slightly in and out, not sure if that's normal. I don't know the first thing about the inner workings of a transmission and I can't seem to find a pic of it anywhere. What is this rod to? How hard is it gonna be to re-seal?
1987 Dodge Power Ram, 1972 440, MP .484 cam, Edel. RPM intake, Edelbrock EPS800 carb., Hedman headers, dual 3" exhuast with Flowmaster mufflers, 3" body lift, 285/75 Mickey Thompson MTX on 16x10 AE 186s
Re: What is the rod on back of TF727? [Re: Groundhawg] #775507
08/16/10 10:34 PM
08/16/10 10:34 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
That is the anchor for the rear band... Properly resealing it requires removing the tail shaft housing & pan... Some guys get away with throughly cleaning the area & smearing RTV over the end of the shaft...
Re: What is the rod on back of TF727? [Re: Groundhawg] #775508
08/16/10 10:36 PM
08/16/10 10:36 PM
Houston TX
GregCon Offline
GregCon  Offline
Houston TX
The rod is the pivot pin for the rear servo. It has an o-ring which must be shot. Yes, the movement is normal, more or less. If it is moving a lot it might be slopped out which would explain the leaking.
Re: What is the rod on back of TF727? [Re: GregCon] #775509
08/16/10 10:44 PM
08/16/10 10:44 PM
Chillicothe, Ohio
Chillicothe, Ohio
Thank you guys! What is involved in removing the tailshaft? Obviously removing the transfer case but is the tailshaft simply bolted onto the back of the tranny or is there internal stuff connecting it? Does the valve body or anthing have to come out? Sorry for all the questions
Re: What is the rod on back of TF727? [Re: Groundhawg] #775510
08/16/10 10:52 PM
08/16/10 10:52 PM
BDW Offline
BDW  Offline
Re: What is the rod on back of TF727? [Re: Groundhawg] #775511
08/16/10 10:53 PM
08/16/10 10:53 PM
Houston TX
GregCon Offline
GregCon  Offline
Houston TX
You unbolt the obvious bolts but then you also have to release the retainer circlip that encircles the rear bearing. There is a plate about 1/2 x 3" held on by two phillips head screws that you remove to access the retainer circlip. It is located beneath the rear tranny mount. If yours in a truck, sometimes the plate is on top of the extension housing rather than on the bottom. (12 o'clock rather than 6 o'clock)
But, you will also need to drop the pan to allow you to slide the pin out and successfully re-install it. No VB removal needed as I recall
Re: What is the rod on back of TF727? [Re: Groundhawg] #775512
08/16/10 10:55 PM
08/16/10 10:55 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Once you drop the transfer case the tail-shaft housing/transfer case adapter will come loose by removing the bolts & spreading the snap-ring.. To get access to the other end of the pin the valve body will have to come out... If your carefull & don't push the shaft out any more than needed the band anchor & pivot should stay when they are... As long as your there get the good molded pan gasket from the dealer, replace the shift shaft seal & kickdown shaft seal....
Re: What is the rod on back of TF727? [Re: GregCon] #775513
08/16/10 10:58 PM
08/16/10 10:58 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I think the wide portion of the VB blocks access... Been a few years there may be access... If the shaft comes out to far things get more complicated.
Re: What is the rod on back of TF727? [Re: 1_WILD_RT] #775514
08/16/10 11:08 PM
08/16/10 11:08 PM
Chillicothe, Ohio
Chillicothe, Ohio
Once again. Thanks guys. Not sure which route I'm going to go. I just replaced the front seal that was leaking on the transfer case a couple weeks ago but I thought my pan gasket was leaking also. Just found out the shaft was leaking and not the pan today. Of course I've got the transfer case back in now. I guess that's how it goes sometimes
Re: What is the rod on back of TF727? [Re: Groundhawg] #775515
08/16/10 11:16 PM
08/16/10 11:16 PM
Houston TX
GregCon Offline
GregCon  Offline
Houston TX
If you have transfer case I am almost sure your access plate is at 12 o'clock.
Re: What is the rod on back of TF727? [Re: GregCon] #775516
08/16/10 11:33 PM
08/16/10 11:33 PM
Chillicothe, Ohio
Chillicothe, Ohio
The transmission is originally out of a 72 Chrysler New Yorker. I had it rebuilt 4yrs ago and they swapped tailshafts in the process.
Re: What is the rod on back of TF727? [Re: Groundhawg] #775517
09/12/10 12:16 AM
09/12/10 12:16 AM
Chillicothe, Ohio
Chillicothe, Ohio
I gooped it with the Right Stuff and so far so good. Thank you guys
