Page 2 of 3 1 2 3
Re: I tryed E 85 on old blue [Re: ajcasini] #775152
08/17/10 12:34 AM
08/17/10 12:34 AM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
pretty
WAXER
Re: I tryed E 85 on old blue [Re: QWK_ENUF] #775153
08/17/10 03:04 PM
08/17/10 03:04 PM
ohio
all spooled up Offline
ohio
good deal john tommy how you doing
Re: I tryed E 85 on old blue [Re: all spooled up] #775154
08/17/10 03:48 PM
08/17/10 03:48 PM
Cedar Lake IN
CRT Offline OP
CRT  Offline OP
Cedar Lake IN
Tommy is doing better, he has a case of "CRS" and he talked to quick fuel, thay said to go up 10 on the intermediate circuit air bleads and that will clear up the intermediate stumble. Going to try that tonight.
Re: I tryed E 85 on old blue [Re: CRT] #775155
08/17/10 04:59 PM
08/17/10 04:59 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Saw E-85 at a staion near work today $2.52 a Gallon! I guess it's too late for me to swap my 440-6 over..lol
Coming soon!!!!
Re: I tryed E 85 on old blue [Re: Mr.Yuck] #775156
08/17/10 08:39 PM
08/17/10 08:39 PM
Az
Crizila Offline
Crizila  Offline
Az
Of course you can't compare gallon to gallon as you have to use significantly more E85 than gasoline. The gain in heat energy is approximately 10% for straight ethanol. Just remember all that heat doesn't go to making HP. Approximately 45% goes out the tail pipe, 30% goes out the cooling system, and 25% makes useable power. 25% of 10% is only 2.5% - so if everything is right, you might gain 2.5% in power - and that's with straight ethanol. Obviously with E85 it will be something less than 2.5%. Since race gas and ethanol have about the same octane rating, if you consider detonation as the limiting factor for making power, it's a wash. The big bennie would come in latent heat of evaporation, aka., heat of vaporization or cooling. With the cooler charge you could possibly run a higher CR and stay out of detonation. Remember, the benefit in HP to running a higher CR really flattens out after about 12:1. After that the engine stresses start to go way up ( look how diesel engines are built ) while power gains rapidly deminish. Add this to the costs involved in modifying your fuel system to handle the addition fuel, toxicity/ afinity for water with ethanol, possible valve recession and lubrication issues, and - well, I aint sold yet. I realize that it will be difficult to put a $ number to all these factors, and some will occur over time, but to some extent, they will occur. JMHO, and I applaude those that are trying it ( even if they gotta deal with green boosters and jet blocks ). I'll keep pumpin Ethal for a while.
Fastest 300
Re: I tryed E 85 on old blue [Re: Crizila] #775157
08/17/10 09:03 PM
08/17/10 09:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
It takes 30% more E-85 to make the same BTU as gas
Re: I tryed E 85 on old blue [Re: MR_P_BODY] #775158
08/17/10 09:55 PM
08/17/10 09:55 PM
toledo, ohio
plasticfantastic Offline
toledo, ohio
I finally got my Lm-1 back so sometime soon I'm going
to check mine out again.... I got it idling nice now
(on my 396ci)but I need to check the mid again
YAY!!!!
Re: I tryed E 85 on old blue [Re: MR_P_BODY] #775159
08/17/10 09:56 PM
08/17/10 09:56 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
If the fuel mixture ratio is stoic for the type of fuel being used, how is more or less of that type of fuel, being either used, or passed through the engine, a factor in percentage of efficiency? Are they (E85 and gasoline) not capable of less than 12.5-1? I don't get the negative. If one is seeing 9 or 10-1, well yes. But 12-1? I don't get it. Help!
Re: I tryed E 85 on old blue [Re: Leigh] #775160
08/17/10 10:38 PM
08/17/10 10:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I'm not really understanding your question... but
stoic is stoic... based on the fuel being used
Re: I tryed E 85 on old blue [Re: plasticfantastic] #775161
08/17/10 10:40 PM
08/17/10 10:40 PM
MR_P_BODY Offline
MR_P_BODY  Offline
YAY!!!!
Yeah I got it idling nice now Doug... no issues there
Re: I tryed E 85 on old blue [Re: Leigh] #775162
08/17/10 10:58 PM
08/17/10 10:58 PM
Az
Crizila Offline
Crizila  Offline
Az
It is better than gasoline in terms of specific energy ( Ethanol = 3.00 SE and Gasoline = 2.92 SE ) since it's low heating value is more than offset by the low stoichiometric air-fuel ratio. In addition, max power is obtained at a much richer ratio so that under these conditions the SE is considerably higher than gasoline, where max power is obtained only at about 20% richer than stoic.
Fastest 300
Re: I tryed E 85 on old blue [Re: Crizila] #775163
08/18/10 11:44 AM
08/18/10 11:44 AM
Az
Crizila Offline
Crizila  Offline
Az
To put this another way - as an example: To make max power with gas, you gotta go 20% richer than the gas Stoic #. To make max power with ethanol, you gotta go 25% richer than its stoic #. More fuel, more power. It appears ( based on the guys on this sight that are using it ), it's good for maybe a tenth in ET. That's significant when your running 9's / 10's.
Fastest 300
Re: I tryed E 85 on old blue [Re: Crizila] #775164
08/18/10 12:29 PM
08/18/10 12:29 PM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
to put it in laymans terms
if you need 108-110 race gas in your race engine than you will SAVE MONEY switching to E85
if you can drive with unleaded pump gas than forget the E85
EXTRA E85 PERKS
saves money
runs cooler
posible performance increase
NEGATIVES
initial conversion cost
so far i have 4 cars i have converted to E85 the no brainer way and all run as good or better than race gas
current cost is 2.09 gal for us and 3 of us are running 9 sec ET's
i luv it
WAXER
Re: I tryed E 85 on old blue [Re: QWK_ENUF] #775165
08/18/10 12:33 PM
08/18/10 12:33 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
I love it.... I was cruisin around town, the water temp got up to about 200 degrees, but the intake manifold was sweating and cold
Re: I tryed E 85 on old blue [Re: joshking440] #775166
08/18/10 04:12 PM
08/18/10 04:12 PM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
I just switched my Mom's Duster over to e85 and will be taking it to the track to try it out today. It ran on pump gas 93 but was pushing the limits with it in the heat. We'll see what it runs.
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: I tryed E 85 on old blue [Re: Jacob Pitt] #775167
08/18/10 04:15 PM
08/18/10 04:15 PM
Odessa, Tx.
cudarex Offline
cudarex  Offline
Odessa, Tx.
Wish we had it in our area. Closest is 4hrs. away.
Re: I tryed E 85 on old blue [Re: Crizila] #775168
08/18/10 06:00 PM
08/18/10 06:00 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
toomuch math for me...ahhhhhhheeee
Coming soon!!!!
Re: I tryed E 85 on old blue [Re: cudarex] #775169
08/18/10 07:23 PM
08/18/10 07:23 PM
Az
Crizila Offline
Crizila  Offline
Az
No real Texan would run E85 Now if you are from Oklahoma,--- Of coures, you can always buy it at the track if you run low
Fastest 300
Re: I tryed E 85 on old blue [Re: CRT] #775170
08/18/10 09:16 PM
08/18/10 09:16 PM
NC
440Jim Offline
440Jim  Offline
NC
E 85 is the hot ticket.
What size gas carb were you running and what size E85 carb did you borrow?
Re: I tryed E 85 on old blue [Re: 440Jim] #775171
08/19/10 09:03 AM
08/19/10 09:03 AM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
We tried it last night and it picked Mom's Duster up a solid .10 in the 1/8th. We figured with the nasty air we had last night that the car would run 7.40-7.42. First pass was a 7.32 backed up by a 7.31. 60' and 330' times are where most of the gain came from. This was just a Quickfuel conversion kit and bigger needle and seats. I jetted it up a few steps and it slowed a little to a 7.33, so I went down past where I started and it went a 7.30. The best pass ever on this pump gas 362" in a 7.23 in good air. So far I like the stuff.
14x Track Champ
Page 2 of 3 1 2 3
