I tryed E 85 on old blue
#775132
08/16/10 02:23 PM
08/16/10 02:23 PM
Posts: 2,771 Cedar Lake IN
CRT
Cedar Lake IN
This weekand, Tommy let me use his E 85 carb and I went to US41 to try it out. I like how it runs cooler, I like the 10th I pick up. I am going to make the switch before Norwalk. The car ran 10.13 @ 130 1.35-60ft 10.14 @ 131 1.36-60ft 10.14 @ 131 1.37-60ft then I had an issue with the carb going WOT, I was bending the throttle bracket. I am going to fix that and try to get the car to run 10.05 to 10.10 E 85 is the hot ticket.
Re: I tryed E 85 on old blue
[Re: CRT]
#775135
08/16/10 02:41 PM
08/16/10 02:41 PM
Posts: 341 Highland beach Fl
poisondart2
Highland beach Fl
about 10*-15* cool, But its the time it takes to get to 190*, I can sit in stageing lanes with the motor running and not worry about getting too hot before a pass. ya the cheap part is cool. E85 was $2.05 in town
Great to hear and it's $2.39 here but better than 13 dollars a gallon I pay now. I cant wait to use it.
[Re: ajcasini]
#775137
08/16/10 02:57 PM
08/16/10 02:57 PM
Posts: 1,552 Michigan
Kiddart
what is the price for you to do my carb. its a 950 proform
Thank you Kiddart
[Re: Kiddart]
#775138
08/16/10 02:59 PM
08/16/10 02:59 PM
Posts: 13,374 Marion, South Carolina [><]
an8sec70cuda
I want to convert my high compression wedge over to E85. Seeing these kind of results makes me want to do it sooner rather than later.
[Re: Kiddart]
#775139
08/16/10 03:04 PM
08/16/10 03:04 PM
Posts: 686 PA
ajcasini
PA
On a normal 4150 conversion you are looking at 350-400.
[Re: CRT]
#775143
08/16/10 04:57 PM
08/16/10 04:57 PM
Posts: 52,972 Romeo MI
MR_P_BODY
The only thing I dont like, is it runs fat when on the intermediate circuit when driving back on the return road, I wish I can go with a two circuit E85 carb, all E85 kits for Doms are three circuit.
I finally got my Lm-1 back so sometime soon I'm going to check mine out again.... I got it idling nice now (on my 396ci)but I need to check the mid again
[Re: pittsburghracer]
#775150
08/16/10 10:22 PM
08/16/10 10:22 PM
Posts: 686 PA
ajcasini
PA
Who does it for that price?
Send ajcasini a pm. He knows what he is doing and is great to deal with. I will be having a little talk with him in the near future.
John is right I do the carbs for that price. There are several others out there that do them as well around that price.
There are also some DIY kits out there that will work for the 4150 and Doms. The 4150 is a little trickier as to make the carb work best on E85 a booster change is normally needed.
If anyone has questions pm me or email at ajcasiniracing@hotmail.com
[Re: modified1090]
#775151
08/16/10 10:26 PM
08/16/10 10:26 PM
Posts: 686 PA
ajcasini
PA
i love it too i hope this isn't considered a highjack but what are you guys watching in the weather do make dialin decisions, temp, humidity, water grains, what?
i run pretty consistent a round 2 or 3 hundreths from day to night
John I do not watch the weather normally when I am running normal brackets at PRP. However I do notice that the humidity seems to affect my ET the most. If the humidity goes up the car slows down.
[Re: Mr.Yuck]
#775156
08/17/10 08:39 PM
08/17/10 08:39 PM
Posts: 7,506 Az
Crizila
Az
Saw E-85 at a staion near work today $2.52 a Gallon! I guess it's too late for me to swap my 440-6 over..lol
Of course you can't compare gallon to gallon as you have to use significantly more E85 than gasoline. The gain in heat energy is approximately 10% for straight ethanol. Just remember all that heat doesn't go to making HP. Approximately 45% goes out the tail pipe, 30% goes out the cooling system, and 25% makes useable power. 25% of 10% is only 2.5% - so if everything is right, you might gain 2.5% in power - and that's with straight ethanol. Obviously with E85 it will be something less than 2.5%. Since race gas and ethanol have about the same octane rating, if you consider detonation as the limiting factor for making power, it's a wash. The big bennie would come in latent heat of evaporation, aka., heat of vaporization or cooling. With the cooler charge you could possibly run a higher CR and stay out of detonation. Remember, the benefit in HP to running a higher CR really flattens out after about 12:1. After that the engine stresses start to go way up ( look how diesel engines are built ) while power gains rapidly deminish. Add this to the costs involved in modifying your fuel system to handle the addition fuel, toxicity/ afinity for water with ethanol, possible valve recession and lubrication issues, and - well, I aint sold yet. I realize that it will be difficult to put a $ number to all these factors, and some will occur over time, but to some extent, they will occur. JMHO, and I applaude those that are trying it ( even if they gotta deal with green boosters and jet blocks ). I'll keep pumpin Ethal for a while.
Fastest 300
[Re: Crizila]
#775157
08/17/10 09:03 PM
08/17/10 09:03 PM
MR_P_BODY
It takes 30% more E-85 to make the same BTU as gas
[Re: MR_P_BODY]
#775158
08/17/10 09:55 PM
08/17/10 09:55 PM
Posts: 2,110 toledo, ohio
plasticfantastic
toledo, ohio
YAY!!!!
[Re: Leigh]
#775160
08/17/10 10:38 PM
08/17/10 10:38 PM
MR_P_BODY
If the fuel mixture ratio is stoic for the type of fuel being used, how is more or less of that type of fuel, being either used, or passed through the engine, a factor in percentage of efficiency? Are they (E85 and gasoline) not capable of less than 12.5-1? I don't get the negative. If one is seeing 9 or 10-1, well yes. But 12-1? I don't get it. Help!
I'm not really understanding your question... but stoic is stoic... based on the fuel being used
[Re: plasticfantastic]
#775161
08/17/10 10:40 PM
08/17/10 10:40 PM
MR_P_BODY
YAY!!!!
Yeah I got it idling nice now Doug... no issues there
[Re: Crizila]
#775163
08/18/10 11:44 AM
08/18/10 11:44 AM
Posts: 7,506 Az
Crizila
Az
It is better than gasoline in terms of specific energy ( Ethanol = 3.00 SE and Gasoline = 2.92 SE ) since it's low heating value is more than offset by the low stoichiometric air-fuel ratio. In addition, max power is obtained at a much richer ratio so that under these conditions the SE is considerably higher than gasoline, where max power is obtained only at about 20% richer than stoic.
To put this another way - as an example: To make max power with gas, you gotta go 20% richer than the gas Stoic #. To make max power with ethanol, you gotta go 25% richer than its stoic #. More fuel, more power. It appears ( based on the guys on this sight that are using it ), it's good for maybe a tenth in ET. That's significant when your running 9's / 10's.
Fastest 300
[Re: Crizila]
#775164
08/18/10 12:29 PM
08/18/10 12:29 PM
Posts: 2,442 LOWELL IN
QWK_ENUF
LOWELL IN
to put it in laymans terms if you need 108-110 race gas in your race engine than you will SAVE MONEY switching to E85 if you can drive with unleaded pump gas than forget the E85 EXTRA E85 PERKS saves money runs cooler posible performance increase NEGATIVES initial conversion cost so far i have 4 cars i have converted to E85 the no brainer way and all run as good or better than race gas current cost is 2.09 gal for us and 3 of us are running 9 sec ET's i luv it
WAXER
[Re: joshking440]
#775166
08/18/10 04:12 PM
08/18/10 04:12 PM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
I just switched my Mom's Duster over to e85 and will be taking it to the track to try it out today. It ran on pump gas 93 but was pushing the limits with it in the heat. We'll see what it runs.
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
[Re: Crizila]
#775168
08/18/10 06:00 PM
08/18/10 06:00 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
toomuch math for me...ahhhhhhheeee
[Re: CRT]
#775170
08/18/10 09:16 PM
08/18/10 09:16 PM
Posts: 16,928 NC
440Jim
NC
What size gas carb were you running and what size E85 carb did you borrow?
[Re: QWK_ENUF]
#775173
08/19/10 01:23 PM
08/19/10 01:23 PM
Posts: 257 madison, ohio
modified1090
madison, ohio
thats not really a negative if you think about it. the couple three hundred bucks or what ever you spend you will save in the first month of racing compared to the price of race gas. some people might not even need a month depending on how much racing you do
[Re: modified1090]
#775174
08/19/10 01:51 PM
08/19/10 01:51 PM
Jacob Pitt
Mansfield, Tx
We only have about $160 in the conversion so far. Pretty cheap for a .10 second increase. I am thinking about putting all the cars on it now.
[Re: 440Jim]
#775175
08/20/10 01:06 AM
08/20/10 01:06 AM
CRT
Cedar Lake IN
Jim, I was running a older 2 circuit 1150 dom, and Tommy let me use his E85 carb that is a 1050 HP 3 circuit. Why do ya ask ?
