TDC Tool #774904
08/16/10 09:59 AM
08/16/10 09:59 AM
Liverpool, NY
SILVER67 Offline OP
SILVER67  Offline OP
Liverpool, NY
Hey Guys,
What do you use for a TDC stop so that you can degree the cam on a BB with Eddy RPM heads?
Michael
Re: TDC Tool [Re: SILVER67] #774905
08/16/10 10:13 AM
08/16/10 10:13 AM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
Just get any flat stock (Make sure it is pretty thick like 1/2 inch at least so it won't flex), drill a hole on each side and slot them so they line up with the head bolts of a cylinder (slotting allows some play), then drill a hole in the center of it and tap it so you can use a bolt as the stop.
Re: TDC Tool [Re: TheOtherDodge] #774906
08/16/10 10:20 AM
08/16/10 10:20 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
you mentioned eddy heads ,if your trying to do it withe heads on ,forget it, the plug angle USUALLY wont allow it.
Re: TDC Tool [Re: bonefish] #774907
08/16/10 12:23 PM
08/16/10 12:23 PM
Liverpool, NY
SILVER67 Offline OP
SILVER67  Offline OP
Liverpool, NY
I'm going to have to pull the head off it sounds to get this truely correct. Will it be okay if I reuse the ARP head bolts? The Eddy heads are brand new as well as the head gasket and head bolts. I should probably buy a new gasket too.
Michael
Re: TDC Tool [Re: SILVER67] #774908
08/16/10 12:28 PM
08/16/10 12:28 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
I'll call you later. You wont need to re-purchase anything.
RIP Monte Smith
Re: TDC Tool [Re: CompWedgeEngines] #774909
08/16/10 12:31 PM
08/16/10 12:31 PM
tboomer Offline
tboomer  Offline
Now there is a stand up shop owner!!
Re: TDC Tool [Re: bonefish] #774910
08/16/10 12:31 PM
08/16/10 12:31 PM
Az
Crizila Offline
Crizila  Offline
Az
Why? Interference with the valves? - and if so, why can't he just disconnect the valve train on # 1 cyl?
Fastest 300
Re: TDC Tool [Re: SILVER67] #774911
08/16/10 12:33 PM
08/16/10 12:33 PM
Did you use the ARP lube and a stretch gauge? Or did you use a torque wrench, either way you can reuse the bolts as long as you didn't over stretch them or over torque them. I have reuse head gaskets, depending on the type and brand, several times on many motors after running the motor on a engine dyno as well as racing them at the track. I have seen professional drag race teams do the same thing The gasket companys and many professional shops won't reuse head gaskest on customer cars, they may reuse them on there own motors Micheal, look closely at the head gaskets, if there fel Pro composition gaskets like the Perma Torque ones, and not torn, bent or damamged in any other way you can reuse them, if there steel shim gaskets like the ones Ma Mopar used from the factory back in the day the same rules apply. If you don't think it is safe for you to reuse them go buy another set
Re: TDC Tool [Re: Crizila] #774912
08/16/10 09:11 PM
08/16/10 09:11 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
the tool goes in the plug hole at too horizontal of an angle.
Re: TDC Tool [Re: bonefish] #774913
08/16/10 10:10 PM
08/16/10 10:10 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
Yep...I did it and just bent the piston stop (the style that goes in the spark plug hole). It did work once it bent though....lol.
