Decode this tag #774784
08/16/10 04:22 AM
08/16/10 04:22 AM
Califor-ni-A!
MrFoFody Offline OP
MrFoFody  Offline OP
Califor-ni-A!
Hello all, I have someone intersted in this car which the seller claims is an original 383 4spd car. Looking at the data tag with the little info I've gathered, I've come to the conclusion that he's full of it but he denies, cries and is ignorant. What is the original motor of this 1964 Plymouth?
Re: Decode this tag [Re: MrFoFody] #774785
08/17/10 12:56 AM
08/17/10 12:56 AM
Califor-ni-A!
MrFoFody Offline OP
MrFoFody  Offline OP
Califor-ni-A!
79 views and no responses? I need some opinions on this so I can direct the seller to this thread.
Re: Decode this tag [Re: MrFoFody] #774786
08/17/10 08:47 AM
08/17/10 08:47 AM
OWL
Culvers Offline
Culvers  Offline
OWL
It should be a Plymouth Sport Fury with the standard 318 engine (there is no code for a bigger engine, so it must be the standard engine), 4-speed transmisson, black interior, white paint, power vent windos, air conditioning,
64 tags are very hard to decode...
Culvers
Re: Decode this tag [Re: Culvers] #774787
08/17/10 10:48 AM
08/17/10 10:48 AM
Pgh, PA
Bull1tt Offline
Bull1tt  Offline
Pgh, PA
VIN will tell which assembly plant, which is helpful.
Re: Decode this tag [Re: Bull1tt] #774788
08/17/10 01:56 PM
08/17/10 01:56 PM
Califor-ni-A!
MrFoFody Offline OP
MrFoFody  Offline OP
Califor-ni-A!
How will the vin help? The data tag holds the engine info. Isn't the 31 in the second row the the engine code?
Re: Decode this tag [Re: MrFoFody] #774789
08/17/10 06:27 PM
08/17/10 06:27 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
... Lynch Road puts the eng code under A-B with the standard eng code not stamped.
...Hamtramck puts the eng code under O-R with standard eng not stamped.
So the VIN having the Assembly plant # in the 4th digit helps.
1-Lynch Road,Mi.
2-Hamtramck,Mi.
3-Jefferson,MI.
4-Belvedere,I.l
5-Los Angeles,Ca.
6-Newark,De.
7-St. Louis,Mo.
This info is from a 1996 code book, there maybe some updated info, and there's guy's on here that know far more than I can help...
Re: Decode this tag [Re: MrFoFody] #774790
08/18/10 01:36 AM
08/18/10 01:36 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
GG's white books show the decodes for Lynch Road and Hamtramck tags. This is where most people go to look for the decode info. The book only shows how to decode a Lynch Road, Hamtramck and Jefferson tag.
This is not a LR built car as the gate and base numbers are not on the top line.
It does not appear to be from St. Louis plant.
The font looks like a thin font LA plant tag. Is it possible this car was built at the LA plant? The VIN would read 3445******.
I don't know how a 64 LA tag is laid out but going by other plants, IF this is an LA plant car, then the 3 under the A might signify a four speed and the 6 under the C might signify the 383.
The guy could be telling the truth. The best way to confirm what the car came with is via the broadcast sheet. Is it or the window sticker available? You could also run the VIN by Chrysler historical to see if they have a copy of the IBM card. That would tell you for sure.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
