Re: Magnum parts on an early la
[Re: Dos Snails]
#774030
08/15/10 05:21 PM
08/15/10 05:21 PM
Posts: 521 somewhereintheswampsofjersey
1swingin
So should I use the amc lifters and magnum pushrods? I would like to use the hyd. rollers but if its gonna be a major modification then I will use a hyd. flat tappet lifter. I just want to make sure Iam using the proper parts for the conversion. Also, are the amc lifters the same height as a mopar lifter or am I going to be buying special length pushrods? Thanks
"I aint here on buisness baby,Iam only here for fun"
[Re: 1swingin]
#774031
08/15/10 06:14 PM
08/15/10 06:14 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
the 85 360 is not setup to use the OEM roller lifters from the Magnum engines.
you can use the retro fit roller lifters if you want to go hydraulic roller cam/ lifters.
otherwise the amc/mopar lifter that oil thru the pushrods are the one to use.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: tubtar]
#774033
08/16/10 09:20 AM
08/16/10 09:20 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
there was a block change for the OEM roller lifters...the lifter bores are taller, and there's some bosses in the valley for the lifter hold downs.
get some retainers off of a 2.2l mopar, and some hughes #1110 springs.
cam, use a flat tappet comp magnum 280H....
