Who makes a good/fairly priced set of plug wires? #773696
08/14/10 06:17 PM
08/14/10 06:17 PM
Mesa, AZ
P
Pat_Whalen Offline OP
super gas
super gas
P
Mesa, AZ
I bought a set of Taylor Spiro-pro wires for my 440 (about 50 bucks) and had two ends pull off on me and I'm not entirely sure they are firing well (Odd miss).
Are the spiro-pros a good set? Should I just recrimp them and be done with it? How about Accel?
I'm not looking to spend too much, this isn't a performance application, per say. Just looking for some tips from the almighty font of knowledge that is moparts. I know I might get 15 differing opinions and I'm ok with that.
Thanks in advance.
Re: Who makes a good/fairly priced set of plug wires? [Re: Pat_Whalen] #773697
08/14/10 06:30 PM
08/14/10 06:30 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Surely you must be talking about the distributor end of the wire pulling apart? I would just recrimp them. When you buy the universal set (cut-to-length) you do your own crimping.
Re: Who makes a good/fairly priced set of plug wires? [Re: Pacnorthcuda] #773698
08/14/10 06:36 PM
08/14/10 06:36 PM
Mesa, AZ
P
super gas
super gas
P
Mesa, AZ
Nope, talking about the 90* boot on the spark end. Happened on two of the 8. I went to pull the wire off (from the boot, not tugging on the wire) and the terminal stayed on the spark plug. I recrimped them the best I could seeing as I don't have an actual spark plug wire crimping tool (ordering one today) and they seem fine.
It wasn't the universal set- it was the premade Taylor Spiro-pro 74072 premade.
Re: Who makes a good/fairly priced set of plug wires? [Re: Pat_Whalen] #773699
08/14/10 08:34 PM
08/14/10 08:34 PM
Puttin' on the foil in Charles...
not_a_charger Offline
Mr. Big Shot Moparts Moderator
Firecore50s.
Earning every penny of that moderator paycheck.
DBAP
Re: Who makes a good/fairly priced set of plug wires? [Re: not_a_charger] #773700
08/14/10 08:54 PM
08/14/10 08:54 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I've heard pretty good things about the taylor wires. Only time I've ever had any plug ends pull off is when I've tried to take a plug wire off while they're still warm. I burnt a couple ends up on my firecore wires and just recrimped them with connectors/boots from napa. I didn't use any special spark plug crimping tool, just my regular electrical crimping tool and I have had no problems. I just made sure to properly strip the insulation to the core of the wire first.
Re: Who makes a good/fairly priced set of plug wires? [Re: Pat_Whalen] #773701
08/14/10 08:58 PM
08/14/10 08:58 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
Moroso Blue Max .
Re: Who makes a good/fairly priced set of plug wires? [Re: 5spdcuda] #773702
08/14/10 09:36 PM
08/14/10 09:36 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
For a daily driver I'd grab a $40 set of cut to length MSD's from vato-zone. They come with a crimping tool as well.
Anything more than that would be money wasted IMO. I'm sure you could get away with less too.
Re: Who makes a good/fairly priced set of plug wires? [Re: Jeremiah] #773703
08/15/10 01:56 AM
08/15/10 01:56 AM
Tulsa, Oklahoma
Wagonmaster Offline
Wagonmaster  Offline
Tulsa, Oklahoma
Best wires I've ever used - haven't tried the ones made by MOPARTS member - are Belden, from Napa. Never had a set of their premium 7MM wires go bad or disintegrate.
The part number for a 440 is: BEL 700130 , the wires are a lifetime warranty [real warranty - just bring 'em in, swap 'em] Cost is $21.49, according to website.
No, I do not work for NAPA. Just like the Belden wires.
Re: Who makes a good/fairly priced set of plug wires? [Re: Wagonmaster] #773704
08/15/10 04:16 AM
08/15/10 04:16 AM
Might just recrimp them as one of their assembly line workers might have had a bad day & got lax/sloppy. Not right but it does happen. Just use your wire crimper pliers as it has a plug wire section and go carefully keeping in mind that your goal is to end up w a round terminal when done so make multiple crimps a bit at a time and until you get it where it meets your satisfaction. Use a GENEROUS spray of silicone lube on the wire so it'll easily go thru the boot then do your crimping then pull it back. Want the lube so you dont make a break in the suppression core by tugging too hard
Re: Who makes a good/fairly priced set of plug wires? [Re: Wagonmaster] #773705
08/15/10 11:38 AM
08/15/10 11:38 AM
Lost in the ozone again
stubbs300 Offline
Vacation
stubbs300  Offline
Vacation
I've never had a problem with any of NAPA's products.
Re: Who makes a good/fairly priced set of plug wires? [Re: stubbs300 ] #773706
08/15/10 12:13 PM
08/15/10 12:13 PM
BDW Offline
BDW  Offline
How do you know when it's time to change your spark plug wires? How long should these things last?
Thx
Re: Who makes a good/fairly priced set of plug wires? [Re: BDW] #773707
08/15/10 01:18 PM
08/15/10 01:18 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
We run the Taylors on all our cars.I even have them on the Harleys.If you pulled an end off they were defective or you pulled awful hard.The ones on my 440 have been on at least 10 years with big tube headers and Ive had them off probally 60 times.Never pulled a boot off.That and they still fire like the day I put them on.Have and had them on at least 6 Mopars with headers.Did you use the diaelectric grease that comes with them?Ill replace mine next year as they are looking pretty old after all these years.Ill still save the old ones though.Rocky
Chrysler Firepower
Re: Who makes a good/fairly priced set of plug wires? [Re: Pat_Whalen] #773708
09/21/10 07:54 PM
09/21/10 07:54 PM
Northeast, PA
sendero Offline
sendero  Offline
Northeast, PA
While I had been happy with Belden( NAPA) ; I just had one cable go after 4 years. It was the short coil to distributor wire. I took that wire in and they said I had to remove the whole set for them to order me the warranty replacement set. With alot of grumbling I did that and they ordered the replacement set ( took 4 business days). Of course, it was the wrong replacement set.
They told me they could reorder and "maybe" get the right set in in another 3 to 4 days. No thanks!
Re: Who makes a good/fairly priced set of plug wires? [Re: sendero] #773709
09/21/10 08:43 PM
09/21/10 08:43 PM
New England
Tech Instructor Offline
New England
Firecores.Contact name sunroof GTX on Moparts.
Re: Who makes a good/fairly priced set of plug wires? [Re: Tech Instructor] #773710
09/22/10 01:13 PM
09/22/10 01:13 PM
Central Ky, area
CHRYCOFAN Offline
CHRYCOFAN  Offline
Central Ky, area
Re: Who makes a good/fairly priced set of plug wires? [Re: CHRYCOFAN] #773711
09/22/10 02:59 PM
09/22/10 02:59 PM
SHELBY TWP,,MICHIGAN
72N96RR Offline
I LOVE WEDGIES
72N96RR  Offline
I LOVE WEDGIES
Buy a set of FireCores and put this problem behind you for good..
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free..
If they come back it means nobody else wanted them either..!!
Re: Who makes a good/fairly priced set of plug wires? [Re: Pat_Whalen] #773712
09/22/10 03:22 PM
09/22/10 03:22 PM
ontario canada
71smiley340 Offline
71smiley340  Offline
ontario canada
I would go with firecores just met him at norwalk
and was impressed. He also has a new distributor set up so you dont have to grind on your heads for clearance.I have mopar perfomance wires on mine pn# p4529032 and have had no problems.Try to give the plug boots a 1/4 turn before pulling on them .
