Any advantage to running mostly antifreeze? #773079
08/13/10 09:22 PM
08/13/10 09:22 PM
Motown, Mi
P
PAULS_340 Offline OP
P
Motown, Mi
Rather than 50/50 is there any advantage to have mostly antifreeze or is there any danger?
Still looking for LM29H1B415501, '71 Demon 340
Re: Any advantage to running mostly antifreeze? [Re: PAULS_340] #773080
08/13/10 09:27 PM
08/13/10 09:27 PM
A Banana Republic near you.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
NO , 50/50 MAX, more antifreeze is not a good thing .
Re: Any advantage to running mostly antifreeze? [Re: PAULS_340] #773081
08/13/10 09:38 PM
08/13/10 09:38 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Running more than 50/50 AF will hinder the cooling .... the BESTest is ZERO AF ...with something like water-wetter.
Re: Any advantage to running mostly antifreeze? [Re: dOc !] #773082
08/13/10 09:46 PM
08/13/10 09:46 PM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
And if you go to the track, they will kick you for having antifreeze in the system. Watch pinks all out when somebody looses it on the track. They get a year ban from the track.
Re: Any advantage to running mostly antifreeze? [Re: None2Slow] #773083
08/13/10 09:49 PM
08/13/10 09:49 PM
Oregon City, OR
Baxter61 Offline
Baxter61  Offline
Oregon City, OR
dont watch pinks all out no matter the reason!
Re: Any advantage to running mostly antifreeze? [Re: Baxter61] #773084
08/13/10 09:54 PM
08/13/10 09:54 PM
Az
Crizila Offline
Crizila  Offline
Az
Fastest 300
Re: Any advantage to running mostly antifreeze? [Re: PAULS_340] #773085
08/13/10 09:54 PM
08/13/10 09:54 PM
(1)No advantage (2) 50/50 protects a system to -35F below zero and more than 50/50 or 70/30 (cant remember which but iirc it's 70/30) the freezing point starts to rise . What Doc Fiberglass said ANY antifreeze hinders heat transfer and if your having a marginal cooling issue (& everything is fixed/changed that should be) then some antirust additive in the water w no antifreeze would be the way to go and water wetter may have rust inhibitors (I'm not sure). I haven't used any type of water wetter so I cant comment but the theory sounds valid
Re: Any advantage to running mostly antifreeze? [Re: RapidRobert] #773086
08/14/10 12:25 AM
08/14/10 12:25 AM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
rust inhibitors
Roger that ....and you should use some something to "lube" the water pump.
Re: Any advantage to running mostly antifreeze? [Re: PAULS_340] #773087
08/14/10 08:27 AM
08/14/10 08:27 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
The Evans NPG coolant
is high ninety percent propylene Glygol, along with additives that make it different than the more conventional 'Sierra' antifreeze.
I have run it in a 360 for nearly ten years.
It does allow running temperatures up to 360 degrees F.
I have not seen any reduction in detonation, as claimed for getting rid of the 'nucleate boiling' which is just a fancy name for little steam bubbles.
Re: Any advantage to running mostly antifreeze? [Re: 360view] #773088
08/14/10 11:03 AM
08/14/10 11:03 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
And remember,if you buy 50/50 pre mix you are buying a half gallon of anti-freeze and a half gallon of water.
Re: Any advantage to running mostly antifreeze? [Re: 62maxwgn] #773089
08/14/10 09:42 PM
08/14/10 09:42 PM
Lebanon ,PA in the Susquehanna...
70Challengerse Offline
and usually more.....
Re: Any advantage to running mostly antifreeze? [Re: 70Challengerse] #773090
08/15/10 12:18 AM
08/15/10 12:18 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
No advantage and a lot of disadvantages.
