What size bolts for trans to block #771980
08/12/10 03:01 AM
08/12/10 03:01 AM
Nampa, ID
None2Slow Offline OP
Nampa, ID
Looking for the length and thread pitch to bolt 904 auto to a non magnum 360. How many might help as well thanks for the help.
Re: What size bolts for trans to block [Re: None2Slow] #771981
08/12/10 09:05 AM
08/12/10 09:05 AM
the house on the left.
cogen80 Offline
cogen80  Offline
this was posted somewhere a while back. apparently you can still get them at the dealer.
4- 6027865
2- 6024863
Re: What size bolts for trans to block [Re: None2Slow] #771982
08/12/10 09:09 AM
08/12/10 09:09 AM
scratchnfotraction Offline
not sure on the bolt size,I go by socket size that fit the head of them
you will have 2 5/8 head bolts that go in to the lower holes from the front
one is captured behind the oil filter and the other is right next to a starter bolt
4 9/16 head bolts go in from the back around the bell housing
there is one more hole in the top middle that will be coverd up by the auto tranz but the manual bell housing would use it to make the 5th 9/16 bolt
i have a bucket full of bolts from mopars over the yrs,let me know and I will send a set to you
the starter will use a stud and nut/nut will be 11/16 IIRC... or 2 5/8 head bolts if it has been removed from the auto tranz bell housing
I have the flex plate to torque converter bolts as well if you need those 4 also
Re: What size bolts for trans to block [Re: scratchnfotraction] #771983
08/12/10 07:21 PM
08/12/10 07:21 PM
Amherst,NY
challengermike Offline
Amherst,NY
3/8 4 of them
7/16 2 of them
Re: What size bolts for trans to block [Re: challengermike] #771984
08/12/10 07:25 PM
08/12/10 07:25 PM
OH,thats why I am allways fused with bolt size
9/16 wrench for a 3/8 bolt
5/8 wrench for a 7/16 bolt
never was good at math
Re: What size bolts for trans to block [Re: scratchnfotraction] #771985
08/12/10 11:53 PM
08/12/10 11:53 PM
Harlan, Ky
O
Orange_Duster Offline
O
Harlan, Ky
Four 3/8-16 1 1/4"long and one 7/16-14 1 3/4" long and one 7/16-14 2" long.
