classic auto air: a-body #771827
08/11/10 10:56 PM
08/11/10 10:56 PM
albemarle, NC
dusterbd13 Offline OP
albemarle, NC
my wife told me tonight that she wants to start using my duster for taking educational family trips around the southeast. she also told me that before spring, we WILL have AC in the car. so....
what mamma wants, daddy wont complain about.
Ive been eyeballing the classic auto air perfect fit kit for years, and dreaming. now, its become a financial reality. the car its going into is a fully "restored", complete, heat only 1970 duster. I'm using a 69 cuda instrument cluster.360 with indybrock heads and a victor Jr manifold. power steering and power brakes. GM 12SI alternator. TTI headers. Aluminum direct fit radiator, with electric two speed dodge intrepid fans. i don't want to cut the car up in any way, nor do i want to do any major changes to other systems or components. hell, i don't even want to drill any holes if i can help it.
anyway, what I'm asking is this:
1. how high quality is the classic auto air kit? would i be better off with something else?
2. how much of a PITA is it to put in?
3. anyone have any pictures of an install other than the bad ones that are on their site?
4. will their compressor setup fit, and will their whole deal work in my car?
thanks for any help you can throw my way.
michael
Michael Crawford CSP 1970 plymouth Duster back under construction: http://www.pro-touring.com/showthread.ph...ouring-makeover 1964 el camino beater shop truck 96403-project-drivabeater-2-0-64-el-camino-this-time
Re: classic auto air: a-body [Re: dusterbd13] #771828
08/11/10 11:16 PM
08/11/10 11:16 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Interesting, and I'm not sure if it'll help.
But,,,,,I'm putting a Vintage Air kit on a 1970 Hemi cuda now. I just started this week so I haven't gotten very far yet. but will post updates next week as I go along
Re: classic auto air: a-body [Re: gtx6970] #771829
08/12/10 12:31 AM
08/12/10 12:31 AM
ST clair shores MI
moretoys Offline
moretoys  Offline
ST clair shores MI
I installed 1 in a small block 68 barracuda.my 68 water pump is different than you're 70.You should be fine.I had alot of shimming/spacer issues.Bracket from intake to compressor and belt tensioner.With that intake,You will probably have some issues with that.Most likely have too cut some spacers.next: the condensor is held in place by being sandwiched in place between radiator and rad support.If you're in the factory location,then you'll be fine.all the heater hoses and a.c. lines go in the factory hole of the original blower motor.No cutting required.inside you will have to add vents on the bottom side of dash frame.The controls might get trickey.It uses you're existing heater controls that you modify with micro switchs.that may or may not cause you problems.since you are altered there.The main problem I had inside the car, was some duct work would not fit in place.because it hit the radio.I ended up warming up the plastic with a propane torch and massaging it to fit.overall not a bad kit,not any original body altering for installation.Another thing different is, you will lose factory glove box liner,A much smaller one comes in the kit.you will get a completely new heater/a.c. box with blower motor built in.Been a few years,these are what I remember off the top of my nogen.
Re: classic auto air: a-body [Re: moretoys] #771830
08/13/10 10:42 AM
08/13/10 10:42 AM
North Dakota
440abody Offline
440abody  Offline
North Dakota
Check out the Bouchillon Performance kit.
http://bouchillonperformance.com/BPEaircondition.asp
73 Dart Swinger 440/727 8.75 w/3.55's
34 Ford 3w coupe with a soon to be 1958 392HEMI!
Re: classic auto air: a-body [Re: 440abody] #771831
08/13/10 03:41 PM
08/13/10 03:41 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I have there kits on both of my cars, BB and SB. Both compressors fit with no problems or shimming. All my pulleys lined up first try on both kits. I have to say, JR knows his Mopars and pulleys.
Re: classic auto air: a-body [Re: Challenger 1] #771832
08/14/10 01:46 AM
08/14/10 01:46 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I haven't installed it yet, but I picked up a universal type under-dash heat/ac kit. I removed my entire stock heater box to make room to mount this thing as far under the dash as I can. Can also routh the heat/ac hoses through the hole the stock blower motor sat in. Seen several guys do it this way. Easy to switch back some day if desired.
Re: classic auto air: a-body [Re: DaytonaTurbo] #771833
08/14/10 01:58 AM
08/14/10 01:58 AM
Tulsa, Oklahoma
Wagonmaster Offline
Wagonmaster  Offline
Tulsa, Oklahoma
Re: classic auto air: a-body [Re: Wagonmaster] #771834
08/14/10 08:22 AM
08/14/10 08:22 AM
Northern OH
rapom Offline
rapom  Offline
Northern OH
I put a classic kit in my 68 charger (360 engine) that was a non a/c car. Kit went in real nice. Kit came with multiple shims for the fan. Tech line was excellent. Just letting you know my experience.
Re: classic auto air: a-body [Re: rapom] #771835
08/14/10 09:01 AM
08/14/10 09:01 AM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
ClassicAutoAir. Tampa Florida. The best. Ice cold for 6 years. No issues. B Body.
The 69 Coronet is the best daily driver. No worries, just pounding with no consequenses. Cold AC.
