no high beams #771572
08/11/10 04:12 PM
08/11/10 04:12 PM
montreal, quebec, canada
jimmy71demon Offline OP
the other night my high beams started flashing on and off. i had to use low beams the rest of the way home. now the high beams dont come on at all. what can cause this? what di i check first?
Im goin fast Mom!
Re: no high beams [Re: jimmy71demon] #771573
08/11/10 04:19 PM
08/11/10 04:19 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I would pull and clean the hi-lo switch from the floor. Squirt WD40 into it and cycle the switch several times. Just a place to start.
Re: no high beams [Re: bboogieart] #771574
08/11/10 04:27 PM
08/11/10 04:27 PM
hooziewhatsit Offline
I lost the headlights completely in my truck when the switch went out. Well, if I hit the floor switch just right, they'd work.
New switch and back to normal
Re: no high beams [Re: hooziewhatsit] #771575
08/11/10 04:31 PM
08/11/10 04:31 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
same thing happend on my cuda new old switch and the lights came back
Re: no high beams [Re: cuda-sweden] #771576
08/11/10 04:36 PM
08/11/10 04:36 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
you can clean them for free if you have some DW40, unless it is extremely crusty. very easy fix, spray up under the plunger (cap) and click the switch and spray several times until the fish-oil comes out clean.
Re: no high beams [Re: bboogieart] #771577
08/11/10 04:43 PM
08/11/10 04:43 PM
alright ill try that guys thanks!
Im goin fast Mom!
Re: no high beams [Re: jimmy71demon] #771578
08/11/10 04:50 PM
08/11/10 04:50 PM
scratchnfotraction Offline
on my 68 dart I had one of the wires almost broke off and would cause it to on off till the high didnt not come on
also had the head light switch burn up causeing the light to go off and on when it got hot
low and high would just go out on that one..
check the wires and plug and clean the switch with wd-40 like said
Re: no high beams [Re: scratchnfotraction] #771579
08/11/10 04:55 PM
08/11/10 04:55 PM
Northeast, Alpine, NY
9
9 Sec Phill Offline
On a road near you
9 Sec Phill  Offline
On a road near you
9
The headlight switch itself has a breaker in it and will shut off the high beams and allow the low beams to work, I would clean the floor switch first, if the problem is still there change out the headlight on/off switch in the dash....Phill
Re: no high beams [Re: bboogieart] #771580
08/11/10 05:00 PM
08/11/10 05:00 PM
So Cal
Sinitro Online content
Sinitro  Online Content
So Cal
I wouldn't recommend WD40 for contact kleener..
Run down to Radio Shack and get some real contact kleener. To kleen the high/low switch, 1st pull/disconnect EZ 1 connector.
Spray the contact kleener into the switch, let it soak a little then work the switch in/out several times. The push action of the switch actually kleens it internal contacts, and if the switch is not often used its contacts get slight layer of oxidation..
Just my $0.00...
