UV Light #770128
08/09/10 09:58 PM
08/09/10 09:58 PM
Mo.
racerx Online work OP
racerx  Online Work OP
Mo.
Anyone know were to purchase those UV lights for checking leaks in you're air conditioner systems?Thaxx.
Re: UV Light [Re: racerx] #770129
08/09/10 10:29 PM
08/09/10 10:29 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I got one at Autozone, under $10 if I remember right.
Re: UV Light [Re: Exit1965] #770130
08/09/10 10:57 PM
08/09/10 10:57 PM
PA
Moparzrule Offline
Moparzrule  Offline
PA
Works much better with the yellow glasses.
http://shop.advanceautoparts.com/webapp/...T%7CGRP2001____
My
Own
Personal
Adrenaline
Rush
Re: UV Light [Re: Moparzrule] #770131
08/09/10 11:15 PM
08/09/10 11:15 PM
Mo.
Mo.
Thaxx. Gentlemen I'll look into both
Re: UV Light [Re: racerx] #770132
08/09/10 11:20 PM
08/09/10 11:20 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
How big a leak are you trying to find? (The fluorescent dye is carried out by the oil, so it has to be a pretty big one to leave UV-visible stains).
IIRC you can get a decent electronic leak detector for around $200, which will find far smaller leaks without dye, but if you're only going to use it once it might just pay to go to a shop and let them "sniff" your system.
Re: UV Light [Re: racerx] #770133
08/09/10 11:25 PM
08/09/10 11:25 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I found this Matco one on Craigs list. Came with a bunch of extras.
Re: UV Light [Re: Challenger 1] #770134
08/10/10 12:30 AM
08/10/10 12:30 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I got one of the LED flashlight style from EBay for about $10 and it has multiple LEDs. Worked great for finding the a/c leak check dye.
Re: UV Light [Re: stumpy] #770135
08/10/10 10:06 AM
08/10/10 10:06 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
I found a UV LED kit at a police supply store and converted my Maglight flashlight.
Craig
Re: UV Light [Re: denfireguy] #770136
08/10/10 12:44 PM
08/10/10 12:44 PM
Missouri
ShelbyDogg Offline
ShelbyDogg  Offline
Missouri
I found the 9 LED UV flashlight at ACE Hardware right by the register junk display for $4.99. said it was for checking money. I use it for A/C.
You can also get a black light bulb at Walmart for $1.86. I also picked up the clip on light fixture with a big aluminum reflector to use it in there.
Rob
3 E-bodies, 70 Challenger R/T, 71 Challenger Vert, 72 5.7 HemiCuda
Rob del Rosario on FB
