Re: UV Light
[Re: stumpy]
#770135
08/10/10 10:06 AM
08/10/10 10:06 AM
Posts: 1,822 Colorado
denfireguy
Colorado
I got one of the LED flashlight style from EBay for about $10 and it has multiple LEDs. Worked great for finding the a/c leak check dye.
I found a UV LED kit at a police supply store and converted my Maglight flashlight. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
Re: UV Light
[Re: denfireguy]
#770136
08/10/10 12:44 PM
08/10/10 12:44 PM
Posts: 39 Missouri
ShelbyDogg
Missouri
I found the 9 LED UV flashlight at ACE Hardware right by the register junk display for $4.99. said it was for checking money. I use it for A/C.
You can also get a black light bulb at Walmart for $1.86. I also picked up the clip on light fixture with a big aluminum reflector to use it in there.
Rob 3 E-bodies, 70 Challenger R/T, 71 Challenger Vert, 72 5.7 HemiCuda
Rob del Rosario on FB
