Magnum swap
#769675
08/09/10 03:03 PM
08/09/10 03:03 PM
Posts: 804 Houston, Texas
racerx20
Standard but OK
Standard but OK
Houston, Texas
I have been eyeballing the new 415 Magnum motor from Indy for my 69 Dart. This question has prob been answered before but couldn't find it via the search.
Can I use the water pump housing and all accessories/brackets off my 340? I would like to retain all of the 69 style stuff. I know the Magnum uses a counter-rotating water pump etc. Also I have heard that the LA valve covers will go onto a Magnum head anyone use them? Any issues with leaks? Thanks
1972 Road Runner
1988 Shelby CSX-T
Re: Magnum swap
[Re: Andrewh]
#769677
08/09/10 06:45 PM
08/09/10 06:45 PM
Posts: 1,522 Ste-Sophie, Quebec, Canada
Wedgeman
Hi there Andrew !!
You are right about the front parts of the engine.
For myself, I'm using the Magnum valve covers gasket with LA covers, the offer a better seal and don't get crushed underbolt pressure, it makes them easily reusable too, many advantages..
Dan
Re: Magnum swap
[Re: Wedgeman]
#769678
08/09/10 07:14 PM
08/09/10 07:14 PM
Andrewh
Hi there Andrew !!
Dan
my mistake about the covers, but the pan is a fact. don't use the la pan and the magnum gasket. you will need a new pan since the 340 and 360 pan's are not the same.
