Re: oil and temp send unit
[Re: mopar70charger]
#767720
08/07/10 04:58 PM
08/07/10 04:58 PM
Posts: 21,073 Niles , Ohio
therocks
Niles , Ohio
BBs used two oil switches one gauge the canister and small light.The temp sender they had 3 for sure.One small for gauge and a large one light.I had an Imperial that had one that had 2 blades sticking up.All the senders have the same thread size.Temp sender Ive seen different size holes on the pump housing.Is this a motor home block?They might be different.My Imperial had signal sentry that had a sender for oil on the passanger side of block also.Rocky
Chrysler Firepower
#767722
08/07/10 07:31 PM
08/07/10 07:31 PM
therocks
Niles , Ohio
The op switch like I said goes directly in the block and there are only 2 and they all have the same thread size.Make sure someone didnt screw an adapter for a mechanical gauge in the hole.The temp sender if you changed housimgs that might be the problem.What connector does your harness have?A lot of the housings have a hole for the sender and a plug that is a different size on the other side.That way either sender fits.Rocky
Chrysler Firepower
[Re: bboogieart]
#767732
08/08/10 02:03 AM
08/08/10 02:03 AM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
pic #5 the canister for the oil pressure gauge. It screws right in where the other sender goes. Same size threads. Man look at how old that box is. Hmmm wonder how long I had that on the shelf. Hope this helps.
