Rebuild 904/LU Where to buy? #767404
08/07/10 01:51 AM
08/07/10 01:51 AM
Nampa, ID
None2Slow Offline OP
Nampa, ID
I have a mid 80's 904lu that I want to rebuild. I will also need a TC of around 2400-2600. Dont want to spend alot, but want something thats going to last. The car is a 1963 Valiant Convertable thats getting a 360. The engine has 10.1, 2.02 valves and a .484 purple shaft cam. Not sure on the gearing as of yet, but around 3.25-3.50. Its going to be a weekend/ nice day car. I already have a tci shift kit for it, but would like some advice on where to get the rest of the parts. Thanks in advance for the help.
Re: Rebuild 904/LU Where to buy? [Re: None2Slow] #767405
08/07/10 08:14 AM
08/07/10 08:14 AM
scratchnfotraction Offline
CRT
Re: Rebuild 904/LU Where to buy? [Re: scratchnfotraction] #767406
08/08/10 12:47 AM
08/08/10 12:47 AM
Nampa, ID
Nampa, ID
What part number should I be looking for? I looked on the site and didn't find anything listed for the 904.
Re: Rebuild 904/LU Where to buy? [Re: None2Slow] #767407
08/08/10 08:08 AM
08/08/10 08:08 AM
my bad..CRT may not do lock up trannys
try your local tranz shop for rebuild kit and a reman TC
Re: Rebuild 904/LU Where to buy? [Re: scratchnfotraction] #767408
08/08/10 09:01 PM
08/08/10 09:01 PM
Nampa, ID
Nampa, ID
What brand should I be looking at for a kit. I don't want some no name made in china crap. The shift kit I have new in box is a transgo tf-1. Is this worth using, or would I be better off getting a complete kit that has this already in it?
Re: Rebuild 904/LU Where to buy? [Re: None2Slow] #767409
08/08/10 09:07 PM
08/08/10 09:07 PM
transgo TF-2
Re: Rebuild 904/LU Where to buy? [Re: RapidRobert] #767410
08/08/10 10:59 PM
08/08/10 10:59 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Rebuild 904/LU Where to buy? [Re: RapidRobert] #767411
08/08/10 11:06 PM
08/08/10 11:06 PM
Nampa, ID
Nampa, ID
I see the TF1 as a street kit and the TF2 as a full race. http://www.summitracing.com/compare.aspx
Why would I want a race shift for a street car that may see the track 1-2 times a year? Just looking for some input. Don't want a car that is uncomfortable to ride in. The wife and kids will be in it.
Re: Rebuild 904/LU Where to buy? [Re: scratchnfotraction] #767412
08/09/10 02:40 AM
08/09/10 02:40 AM
Martinsville, VA
440child Offline
440child  Offline
Martinsville, VA
Try calling CRT for a price on a l/u trans. I called about one for my '85 Ram p/u & iirc he quoted me $600. Can't remember the price for the converter, tho. These guys have the 904 l/u converters in different stall speeds http://www.transmissioncenter.net/dodge.htm .
Re: Rebuild 904/LU Where to buy? [Re: None2Slow] #767413
08/09/10 11:17 AM
08/09/10 11:17 AM
Kissimmee Fl.
Kissimmee Fl.
the TF1 is more a HD/towing kit the TF2 is not a full race kit it is there street/strip kit the TF3 is the full race manual kit
Re: Rebuild 904/LU Where to buy? [Re: dusturbd340W5] #767414
08/09/10 03:05 PM
08/09/10 03:05 PM
Nampa, ID
Nampa, ID
Would this be the kit I should look at with the TF-2?
http://www.summitracing.com/parts/TCI-129000/
Re: Rebuild 904/LU Where to buy? [Re: None2Slow] #767415
08/09/10 03:23 PM
08/09/10 03:23 PM
P
Paul_Fancsali Offline
P
I would strongly consider not using a lockup trans with that cam You may be asking for a surging and other udesireable problems Just a thought!
Re: Rebuild 904/LU Where to buy? [Re: Paul_Fancsali] #767416
08/09/10 03:35 PM
08/09/10 03:35 PM
Nampa, ID
Nampa, ID
Unfortunatley, it's what I have. Its not really in the budget to change that. Can I change out the input shaft to eliminate this function? Also, where can I get a input shaft for the driveline. Around here they want $150 for a stock driveline and wont seperate the input. I am putting in a Ford 8" and will need a custom driveshaft made. When I got the car, it had an A833 and a tired 318. I am going with the 904 as it came with the car and was from a working patrol car, right up until it was t-boned. I just want to do it once and not have to pull it in a few years or sooner if I kill it.
Re: Rebuild 904/LU Where to buy? [Re: None2Slow] #767417
08/09/10 04:13 PM
08/09/10 04:13 PM
you can block the loc-up valve on the VB and get a reman TC with the guts left out to make it non loc-up(or just block the loc-up valve)
with out changing the input shaft
you will need a smaller 904 slip yoke as the od 833 use a large slip yoke like a 727
IMO,just a rebuild and block the loc-up valve and run the TC thats in it
should be the HD a999 if it a police car tranz,IIRC
Re: Rebuild 904/LU Where to buy? [Re: scratchnfotraction] #767418
08/09/10 05:24 PM
08/09/10 05:24 PM
Nampa, ID
Nampa, ID
The driveline that was in it has the 4 bolt flange. As for the TC, can I get 1 for a non l/u and use it? I need to buy a new 1 anyways. Is the steps to block the l/u function in the atsg manual? Thanks for the help and keep em comming
Re: Rebuild 904/LU Where to buy? [Re: None2Slow] #767419
08/09/10 06:41 PM
08/09/10 06:41 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
SMR transmission do sell LU torques
Dan
Re: Rebuild 904/LU Where to buy? [Re: Wedgeman] #767420
08/09/10 08:07 PM
08/09/10 08:07 PM
bumped the old post on blocking the loc-up
"A-999 locking converter"
good read and info
Re: Rebuild 904/LU Where to buy? [Re: None2Slow] #767421
08/10/10 09:04 AM
08/10/10 09:04 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
nope, spline is different.
2017 Grand Cherokee Overland
Re: Rebuild 904/LU Where to buy? [Re: scratchnfotraction] #767422
08/10/10 10:01 AM
08/10/10 10:01 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Another option is to modify the lockup valve to engage at 40mph instead of 30 so there is a little bit less torque at lockup. There was a TSB on these transmissions for shudder. The Transgo kits do modify the lock up valve body but does not have the substitute spring for the valve. There is a cheap 20 dollar shift kit out there that does have a new spring. I used the spring and tossed the other stuff but kept the nifty drill bits.
I do not have any road experience yet with this lashup as my engine is not yet complete. Just threw this out for something else to worry or think about!
The rebuild kit I used was an Alto Red kit with Kolene steels.
Craig
Re: Rebuild 904/LU Where to buy? [Re: denfireguy] #767423
08/19/10 03:38 PM
08/19/10 03:38 PM
Nampa, ID
Nampa, ID
I just went and looked at the TC that I got with the 904 I have. It has a sticker on it that says
HS
LOCK
UP
Is this a high stall l/u? I will try to post the trans numbers later today.
Thanks for the help
edit:
I looked at the numbers and this is what i got. The first 2 were not stamped really well, but this is the best I could do.
PK4295887X 7656 9964
If you could help me find what I have to work with, I would appreciate it.
