anyone running a third brake light?? #766975
08/06/10 03:15 PM
08/06/10 03:15 PM
Anchorage,AK
AK_JH27 Offline OP
AK_JH27  Offline OP
Anchorage,AK
Thinking about adding one to my charger just to add a little more awareness of me stopping. My car kinda sits low all around and with most of the newer trucks, they sit pretty high, we have a ton of them here. that they might not see my taillights in traffic.
any aftermarket setups out there?
Re: anyone running a third brake light?? [Re: AK_JH27] #766976
08/06/10 03:20 PM
08/06/10 03:20 PM
minnesota
Kirby Offline
Kirby  Offline
minnesota
I "frenched" one in the bottom of my go-wing on my 71 Cuda'- 14" LED- wired to my brake switch.
Re: anyone running a third brake light?? [Re: AK_JH27] #766977
08/06/10 03:22 PM
08/06/10 03:22 PM
Spokane Valley, WA
Big Bad Bee Offline
Big Bad Bee  Offline
Spokane Valley, WA
I don't think you could lose installing one. I plan to. So many people text and talk on the cell phone while driving. Rearend accidents are the #1 most common. I plan to just run one of those single row LED strips so that it's low profile. Sure would be cool to mold one into my go-wing...
I’m listening.
Re: anyone running a third brake light?? [Re: AK_JH27] #766978
08/06/10 03:33 PM
08/06/10 03:33 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
yes they are available
DON'T wire it from tail lights itself since will be working with turning and hazzards. Wire it directly from pedal switch
BTW a guy what I know inserted a third stop light into the deck lid rear face, above trunk cilinder. On a 73 Charger. Doesn't look bad at all! I wouldn't do it, but does look nice
Of course, needs a body job
Re: anyone running a third brake light?? [Re: NachoRT74] #766979
08/06/10 03:44 PM
08/06/10 03:44 PM
Anchorage,AK
AK_JH27 Offline OP
AK_JH27  Offline OP
Anchorage,AK
thanks for all the advice. I plan on installing it just inside the rear glass near the top.
Re: anyone running a third brake light?? [Re: AK_JH27] #766980
08/06/10 03:45 PM
08/06/10 03:45 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
GOOD idea ... they make some nice-ones with LED's now I hear. And good point about wiring it into the brake pedal directly.
Re: anyone running a third brake light?? [Re: dOc !] #766981
08/06/10 04:07 PM
08/06/10 04:07 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
5549 post on old board
Re: anyone running a third brake light?? [Re: 05dakota] #766982
08/06/10 05:01 PM
08/06/10 05:01 PM
Toronto, Ont, Canada
boydsdodge Offline
boydsdodge  Offline
Cool
Re: anyone running a third brake light?? [Re: 05dakota] #766983
08/06/10 05:28 PM
08/06/10 05:28 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
i use this:
http://www.brakeflasher.com/brake.htm
NEAT idea ... but almost 70 bux ?? ...
Re: anyone running a third brake light?? [Re: AK_JH27] #766984
08/06/10 06:56 PM
08/06/10 06:56 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
Out of a '92 (IIRC) Maxima. Bottom trimmed for height and angle. Painted to to match, as best as possible, the dark green interior. Mounted on a flat piece of sheet metal that slides under the the bottom of the lower inside window trim, between the trim and package tray trim. The sheet metal is covered with leftover headliner material for extra thickness and to match.
I posted a thread many moons ago. Probably still out there somewhere.
Wire runs directly from brake light switch for proper operation. Only downside is incandescent bulb, which is not as fast as LED.
Re: anyone running a third brake light?? [Re: MoparMarq] #766985
08/06/10 06:58 PM
08/06/10 06:58 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
From outside...
Re: anyone running a third brake light?? [Re: MoparMarq] #766986
08/06/10 07:05 PM
08/06/10 07:05 PM
Anchorage,AK
AK_JH27 Offline OP
AK_JH27  Offline OP
Anchorage,AK
thats exactly what i'm looking to do. thanks
Re: anyone running a third brake light?? [Re: AK_JH27] #766987
08/07/10 11:15 AM
08/07/10 11:15 AM
North of the Motor City
DartGTDan Offline
DartGTDan  Offline
I picked up a 3rd brake light from a boneyard 1986-1988 Chevrolet Corsica. I installed 6 LED guts from a boneyard 2005 Jeep Grand Cherokee. Painted it satin/flat black. Will mount much like MoparMarq did (some day).
