Weight transfer/front end rise basic question #766164
08/05/10 03:44 PM
08/05/10 03:44 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Bear with me, and try to remember I'm
mostly a street guy....
I've got stock, big torsion bars and SS springs on my GTX, and all newer OEM type rubber bushings in it.
On a launch, the rear lifts a bunch but the front just sits there and does nothing.
It does drive nicely on the street, but 60' is very inconsistant at the strip, and over the years I've found it's a little too dependant on track prep compared to more strip oriented cars than mine. Best 60' ever has been a 1.55, but that was with stellar track prep on a perfect day. Average seems to be in the 1.6s and I'd like to improve on that a bit.
Which is going to make a greater improvement in front end rise...lighter torsion bars, or freeing up the control arms? I'm looking at a pair of MP drag bars for sale and thinking about trying them.
Rich H.
Esse Quam Videri
Re: Weight transfer/front end rise basic question [Re: ZIPPY] #766165
08/05/10 03:49 PM
08/05/10 03:49 PM
what front shocks are you using on the car?
Re: Weight transfer/front end rise basic question [Re: ZIPPY] #766166
08/05/10 03:51 PM
08/05/10 03:51 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
Mopar Enthusiast Article
Rich - I did this a few months back and was surprised at the gains we saw.
Re: Weight transfer/front end rise basic question [Re: DJVCuda] #766167
08/05/10 04:48 PM
08/05/10 04:48 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Cab, currently QA1 Stocker Stars set full loose
(which I feel is still too tight, and could probably use a revalving to QA1R instead).
Dave, Yep I have that article...probably should have mentioned I subscribe in old fashioned paper format
What I was really looking for is some guess at a noticeable gain with a torsion bar + shock change. If it's worth it to try that, I wanted to leave the control arms alone for now since the OE bushings have only got a couple thousand miles on them and I didn't enjoy replacing 'em at the time.
Rich H.
Esse Quam Videri
Re: Weight transfer/front end rise basic question [Re: ZIPPY] #766168
08/05/10 05:36 PM
08/05/10 05:36 PM
Locomotion Offline
Locomotion  Offline
No need to change anything with the upper control arms.
Cheap OEM shocks can provide quick lift, but they also have very little resistance on compression. Not good for headers or deep oil pan. I found Koni SPA-1 shocks to work well for my combo. I took my time and followed instructions carefully to get them equal. But i forgot "where" I set them at, possibly about 3/4 loose, but it's been a while since I installed them. Smaller torsion bars will also help. Unfortunately, there will be some compromise in handling on the street with these changes.
A little extra carb tuning (pump cam and squirters) may also help by minimizing any rich or lean spots, which may not always be obvious. The purpose is to keep the application of power to the suspension as smooth as possible so it doesn't unload to any degree.
A long time ago I had a home-built Challenger with ladder bars. It wasn't the best set-up, but worked ok. Adding 130lbs helped consistency a noticable amount.
Re: Weight transfer/front end rise basic question [Re: Locomotion] #766169
08/05/10 06:11 PM
08/05/10 06:11 PM
Clinton Twp... north of Deetro...
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
Zipster...do yourself a favor and get a set of Calverts! Just about everybody who's tried them REALLY like them! I went from Lakewood 90/10's to them and it made a BIG difference in front-end rise! NO PROBLEM AT ALL on the street either! The smaller bars should be beneficial as well! I put on the .840 drag bars about 3 yrs. ago,noticeable difference from the stock bars! RandyB
Re: Weight transfer/front end rise basic question [Re: Labratt] #766170
08/05/10 06:24 PM
08/05/10 06:24 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
I like the way your car leaves Randy, your chassis is working 100 times better than mine. thanks
Rich H.
Esse Quam Videri
Re: Weight transfer/front end rise basic question [Re: ZIPPY] #766171
08/05/10 07:24 PM
08/05/10 07:24 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I changed my 340 GTS bars for 6 cyl and went from 1.74 to 1.62 and pulled both wheels off the floor.
Mick
Re: Weight transfer/front end rise basic question [Re: deaks] #766172
08/05/10 10:28 PM
08/05/10 10:28 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Sounds promising, thanks.
I think I need to try the bars and find out how they act, and whether they're going to be liveable on the street for me.
Appreciate the responses
Rich H.
Esse Quam Videri
Re: Weight transfer/front end rise basic question [Re: ZIPPY] #766173
08/05/10 10:31 PM
08/05/10 10:31 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
I agree with Randy,,,
there was someone on the board selling some .840 bars
the calvert shocks are fairly inexpensive,,,,
I put them both on the Belvedere as well recently,,but havent had the chance to try them out.
Re: Weight transfer/front end rise basic question [Re: ZIPPY] #766174
08/05/10 11:10 PM
08/05/10 11:10 PM
Circleville, Ohio
E
Evil67 Offline
Evil67  Offline
E
Circleville, Ohio
On my 71 i raised rear a little and stiffened shocks - improved 60' .2sec.....it was a 4 link car though but same front setup as yours. oh well ...just thought i would put my 2cents in...maybe help????
Former Username - 71Cuda
Current Ride: 1967 Dart - 340
Re: Weight transfer/front end rise basic question [Re: Evil67] #766175
08/05/10 11:47 PM
08/05/10 11:47 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
BACK IN THE DAY WE DRILLED A HOLE IN THE FRONT SHOCKS
home of the
Sox and Martin Hemi Duster
Re: Weight transfer/front end rise basic question [Re: HEMIFRED] #766176
08/06/10 12:55 AM
08/06/10 12:55 AM
I keep a set of those in the trailer sometimes a drilled shock on the right side(paasenger) can make the difference in hooking and not hooking
Re: Weight transfer/front end rise basic question [Re: Cab_Burge] #766177
08/06/10 12:59 AM
08/06/10 12:59 AM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
Any pics of these drilled shocks??
Re: Weight transfer/front end rise basic question [Re: HEMIFRED] #766178
08/06/10 01:08 AM
08/06/10 01:08 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
they must have been a ball of fun when lifting or hitting the brakes at speed.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Weight transfer/front end rise basic question [Re: MIKES_DUSTER] #766179
08/06/10 01:16 AM
08/06/10 01:16 AM
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
Mike,I'll post one tomorrow! Mike Ricketts(Macomb Missile)gave me a set to try out a few yrs.ago! They definately transfer the weight nicely...just don't hit a hole on your return trip!!! I thought ALL my fillings and bridge were going to come flyin' out of my mouth! Needless to say,they've been on the pole barn shelf since! RandyB
Re: Weight transfer/front end rise basic question [Re: Labratt] #766180
08/06/10 01:21 AM
08/06/10 01:21 AM
LOL...Thats funny!!!!
Re: Weight transfer/front end rise basic question [Re: bigtimeauto] #766181
08/06/10 01:24 AM
08/06/10 01:24 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
I laugh when looking back at things we tried. besides the drilled shock. CAB pointed that out
I can remember running a 7" B-140 M&H slick on a 5" rim with 2 lb of air. Yes TWO POUNDS !!
We thought those skinny rims would push down more weight on the center of the slick.
The first time I did that and reached the traps I nearly pooped in my draws.
The entire rear of the car would sway side to side about 2 feet.
thankfully the front tracked straight.
The tire or maybe the rim would move left to right from bead to bead.
After the first time I got used to it but it sure was crazy
home of the
Re: Weight transfer/front end rise basic question [Re: HEMIFRED] #766182
08/06/10 01:47 AM
08/06/10 01:47 AM
USA
BB Dart 69 Offline
BB Dart 69  Offline
USA
ONT SHOCKS
I was thinking the same thing, wicked on the street!
Re: Weight transfer/front end rise basic question [Re: 69CHARGERMD] #766183
08/06/10 02:05 AM
08/06/10 02:05 AM
Pennsylvania
proshiftcharger Offline
Pennsylvania
What is the size of the small block V-8 original factory torsion bar?
Compared to the .840 drag bar Im wondering whats lighter and would transfer weight better between the S/B V-8 and the .840 drag bar??
