BB440 oil pump gasket? #766010
08/05/10 12:02 PM
08/05/10 12:02 PM
Southern Oregon
toyotajeep Offline OP
Southern Oregon
Good morning,
I am putting my new 440 together and I couldn't find a gasket for the oil pump.
I believe I ran into this before. This is using the typical Fel-Pro kit which is 2110 I think. It has every gasket I have needed so far, including the oil pump O ring.
But no base gasket between the pump body and the block?
They do use one, correct?
1989 Dodge Cummins & 1989 Dodge W-250
Re: BB440 oil pump gasket? [Re: toyotajeep] #766011
08/05/10 12:08 PM
08/05/10 12:08 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
Yes.....they use a gasket.
Mopar number for the gasket and O rings is 2084355. Sometimes a little tough to find.
Get your dealer to do a search.
Re: BB440 oil pump gasket? [Re: superwrench] #766012
08/05/10 12:14 PM
08/05/10 12:14 PM
Southern Oregon
Southern Oregon
I figured that would be the trick.
It seems strange that it is not in the kit. Definately not in there.....think Rainman repeating.....
Anyways, aside from the strange humor here I will do some checking.
I'd like to get it online since I am 50 miles from town and the local parts store stink
Maybe I can get it at Summit.
Thanks, just as I suspected.
ROB
Re: BB440 oil pump gasket? [Re: toyotajeep] #766013
08/05/10 12:24 PM
08/05/10 12:24 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: BB440 oil pump gasket? [Re: MoparforLife] #766014
08/05/10 12:29 PM
08/05/10 12:29 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
NAPA has them as a kit with O rings.Any good part store shold have them or be able to order them.Rocky
Chrysler Firepower
Re: BB440 oil pump gasket? [Re: therocks] #766015
08/05/10 12:39 PM
08/05/10 12:39 PM
Southern Oregon
Southern Oregon
I found them at Mancini, thank you. I will try and find it local at Napa.
The main store I shop at was of no use. Even Summit didn't have the kit....
I'll post up when I find the number.
Back in bit.....
ROB
Re: BB440 oil pump gasket? [Re: toyotajeep] #766016
08/05/10 12:42 PM
08/05/10 12:42 PM
Southern Oregon
Southern Oregon
I am thinking I need the kit that looks like this: http://chucker54.stores.yahoo.net/oilpumpgasket.html
But most places show the kit that looks like this:
http://www.napaonline.com/Search/Results...5+50022+2022016
Isn't there supposed to be a paper gasket in there like the Mancini kit?
2-3 local parts houses show the O-ring as all there is. I have that in my kit.
For obvious reasons I need to get this right.
Thanks for the help.
ROB
Re: BB440 oil pump gasket? [Re: toyotajeep] #766017
08/05/10 12:56 PM
08/05/10 12:56 PM
Southern Oregon
Southern Oregon
Hughes has them too.
Napa does not. The guy there says that they sell the o ring but not the gasket. He says the only time he sees the gasket is when you buy the oil pump.
So.......I will see what I can come up with. It is more of a time thing, not $.
I will call another parts house or two.
ROB
Re: BB440 oil pump gasket? [Re: toyotajeep] #766018
08/05/10 01:07 PM
08/05/10 01:07 PM
Upper Midwest
Upper Midwest
ROB
That is the one that I posted way above this
Re: BB440 oil pump gasket? [Re: toyotajeep] #766019
08/05/10 03:21 PM
08/05/10 03:21 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Keep a few hanging on a nail on the wall, and be careful about how many you hand out to your buddies when they come around. Because one day you'll need one in a pinch, just like those guys, and you won't have jack!
Re: BB440 oil pump gasket? [Re: buildanother] #766020
08/05/10 03:59 PM
08/05/10 03:59 PM
Clintwood VA
johnedod Offline
johnedod  Offline
Clintwood VA
If all else fails get some gasket material and a small ball peen hammer and make one.
Johnedod
68 Road Runner
71 Road Runner
78 Power Wagon
Re: BB440 oil pump gasket? [Re: johnedod] #766021
08/05/10 05:02 PM
08/05/10 05:02 PM
Get one of those thin green/yellow/red manila folders, cut it w scissors, punch/trim the holes w the ball peen & lightly coat it w Permatex "high tack", the red stuff, several years & counting workin perfect
Re: BB440 oil pump gasket? [Re: RapidRobert] #766022
08/05/10 05:38 PM
08/05/10 05:38 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
Give me your address and i will mail you one
Re: BB440 oil pump gasket? [Re: johnedod] #766023
08/06/10 12:33 AM
08/06/10 12:33 AM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
Last time I refreshed my 440 I couldn't find one anywhere. I ended up making mine.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: BB440 oil pump gasket? [Re: Joesixpack] #766024
08/06/10 10:54 AM
08/06/10 10:54 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Me to, and a premium one @ that
Re: BB440 oil pump gasket? [Re: roadhazard] #766025
08/06/10 11:13 AM
08/06/10 11:13 AM
Southern Oregon
Southern Oregon
Wow, the generosity of this site is pretty incredible. I have no idea why they don't include one in the kit. It has everything else but no gasket for the OP? Strange.....
I did end up calling everyone in town, including the dealer. No one had it, and the dealer did not return my call.
I am going to make one, and the next time I order some parts online I will get a stack of them.
It is the weird little stuff that gets you.
The story on the build of my car is long.
But I have my nieces coming in two weeks and I want to take them for a spin in a loud muscle car. That is something that will leave an impression. I am a shop teacher and I can tell you that todays kids don't really relate to the old stuff. They like it, but don't really "get it".
It is a mild 440 with a 3" exhaust and 4.10's in an A body. Should be memorable for them and me. I have never driven anything really close to a "hot rod". If you count a 289 with 3.50 gears a hot rod
Thank you so much.
ROB
Re: BB440 oil pump gasket? [Re: toyotajeep] #766026
08/06/10 12:08 PM
08/06/10 12:08 PM
Upper Midwest
Upper Midwest
My McCord kits have always had them included.
Re: BB440 oil pump gasket? [Re: MoparforLife] #766027
08/06/10 02:39 PM
08/06/10 02:39 PM
Southern Oregon
Southern Oregon
I think it is the Fel Pro kit # 2110 that is the culprit.
Maybe I should look at the McCord next time.
It is really weird that it is not in there......
ROB
Re: BB440 oil pump gasket? [Re: toyotajeep] #766028
08/06/10 09:39 PM
08/06/10 09:39 PM
But I have my nieces coming in two weeks and I want to take them for a spin in a loud muscle car. That is something that will leave an impression. It is a mild 440 with a 3" exhaust and 4.10's in an A body. Should be memorable for them and me.
It will
