Trend pushrod failure
#765634
08/04/10 11:13 PM
08/04/10 11:13 PM
Posts: 6,295 U.S.
moparniac
U.S.
these are new! ....... .135 wall $270 pushrods. im calling best machine in the morning. luckily this only happened when I was cranking the engine over and didt fall down into the engine... ![](/ubbthreads/images/graemlins/flame.gif) I dont trust any of them in my engine now!!! I want a whole new lot! ![](http://a.imageshack.us/img829/3329/trend001.jpg)
Mopar Performance
Re: Trend pushrod failure
[Re: moparniac]
#765635
08/04/10 11:15 PM
08/04/10 11:15 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
WOW ![](/ubbthreads/images/graemlins/eeek.gif) my new Mantons should be here tomorrow would hate to see something like that happen
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: dusturbd340W5]
#765636
08/04/10 11:25 PM
08/04/10 11:25 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Before you try another take a good flashlight and have someone turn the engine over to make sure the pushrods are not rubbing on the block or heads. I had some major grinding to do on both my Keith Black block and the 440-1 heads but I am using 1.6 rockers.
[Re: pittsburghracer]
#765637
08/04/10 11:35 PM
08/04/10 11:35 PM
Posts: 6,295 U.S.
moparniac
U.S.
1.65 TDs here... block was clearanced and I had the heads pushrod clearanced also... heads/pushrods came from same place! I am gonna look things over more closely tomorrow! I have everything apart right now! Just seems to clean of a break for me! ![](http://a.imageshack.us/img193/6734/liftervalley001.jpg)
Mopar Performance
[Re: bigtimeauto]
#765640
08/05/10 05:41 AM
08/05/10 05:41 AM
Posts: 6,295 U.S.
moparniac
U.S.
It was an exhaust on #8 . this pushrod has no marks on it!
Mopar Performance
[Re: moparniac]
#765641
08/05/10 08:13 AM
08/05/10 08:13 AM
Posts: 13,386 Marion, South Carolina [><]
an8sec70cuda
I'd call up Manton and order a good set.
[Re: HardcoreB]
#765645
08/05/10 12:05 PM
08/05/10 12:05 PM
Posts: 6,295 U.S.
moparniac
U.S.
Well the heads/ pushrods / rockers and spring package all came from the same place all new !!! PtoV was .110 intake and .140 exhaust ... I'm not blaming Best Machine here one bit so no one twist that! They have contacted Trend and I am sending the whole lot to trend to be analyzed ... I have about 180 miles on my engine I believe it will be on my new odometer I installed. Once and if the pushrod was to blame we will go from there !!! Best Machine has been top notch to me from day one when I first bought all if this...
Mopar Performance
[Re: DoubleD]
#765648
08/05/10 01:36 PM
08/05/10 01:36 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
I would tend to think its a break based o9n some some of meterial issue or during the heat treating process. I believe Trend buys there moly tubing in 21' lengths. ( maybe rolls but I dont think so) Once they determine what lengths they need. the tubing will go thru an annealing process. Thats usually about 1-2" from the finished end of the required tube length. I'd have to guess, they may find a problem in that arena. john is a good guy at Trend, and he will get you an answer for sure. It will be interesting to see what they find.
RIP Monte Smith
[Re: moparniac]
#765649
08/05/10 03:14 PM
08/05/10 03:14 PM
Posts: 43,292 Bend,OR USA
Cab_Burge
I have seen Smith Bros. do the same thing, I had one break during a pull on the dyno, it broke the top off of a Crwoer roller lifter and ended up guaging the cam lobe ![](/ubbthreads/images/graemlins/rant.gif) On eof my freinds had the same thing happen on another set of Smith Bros but it broke at the very top under the ball cup end, mine had a defect in the material where it broke ![](/ubbthreads/images/graemlins/down.gif) I now have Mantons in all of my motors, PM if you want a set. I'm a dealer for all three companys ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: moparniac]
#765652
08/06/10 04:17 PM
08/06/10 04:17 PM
Posts: 3,695 nc
emarine01
nc
See if you can look thru the spark plug hole with a good bore scope , check the exhaust relief in the piston for a contact mark, You wont always bend a valve with piston to valve contact, We broke a push rod in the middle like that pic of yours, turned out to be a guide that was too tight, I ran this engine for 2 weeks on and off at the shop and it was fine, broke the push rod on the return road after the first pass, I ended up pullin the heads cause I couldn't find the problem, I bought a good bore scope the next day ![](/ubbthreads/images/graemlins/hammer.gif)
[Re: emarine01]
#765653
08/06/10 05:00 PM
08/06/10 05:00 PM
Posts: 6,295 U.S.
moparniac
U.S.
no bore scope here .... Im just gonna have to wait and see what trend says as they are gonna inspect them over! Its hard to believe a ptov contact (if the valve hung open like you said) wouldnt bend a valve but snap a thick "Trend" .135 wall HD pushrod so clean like that... youd think the valve would bend and pushrod bend before that happened to a "Trend" pushrod... ![](/ubbthreads/images/graemlins/shruggy.gif) should know something from Trend next week!
Mopar Performance
