Page 1 of 3 1 2 3
Trend pushrod failure #765634
08/04/10 11:13 PM
08/04/10 11:13 PM
U.S.
moparniac Offline OP
U.S.
these are new! ....... .135 wall $270 pushrods. im calling best machine in the morning. luckily this only happened when I was cranking the engine over and didt fall down into the engine...
I dont trust any of them in my engine now!!!
I want a whole new lot!
Mopar Performance
Re: Trend pushrod failure [Re: moparniac] #765635
08/04/10 11:15 PM
08/04/10 11:15 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
WOW my new Mantons should be here tomorrow would hate to see something like that happen
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Trend pushrod failure [Re: dusturbd340W5] #765636
08/04/10 11:25 PM
08/04/10 11:25 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Before you try another take a good flashlight and have someone turn the engine over to make sure the pushrods are not rubbing on the block or heads. I had some major grinding to do on both my Keith Black block and the 440-1 heads but I am using 1.6 rockers.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Trend pushrod failure [Re: pittsburghracer] #765637
08/04/10 11:35 PM
08/04/10 11:35 PM
U.S.
U.S.
1.65 TDs here... block was clearanced and I had the heads pushrod clearanced also... heads/pushrods came from same place! I am gonna look things over more closely tomorrow! I have everything apart right now!
Just seems to clean of a break for me!
Mopar Performance
Re: Trend pushrod failure [Re: pittsburghracer] #765638
08/04/10 11:42 PM
08/04/10 11:42 PM
U.S.
U.S.
I checked this all out when engine was on the stand.... Ill look closer in the morning at things....
Mopar Performance
Re: Trend pushrod failure [Re: moparniac] #765639
08/05/10 01:28 AM
08/05/10 01:28 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
do you have offset intake lifters? Was it a intake?
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Trend pushrod failure [Re: bigtimeauto] #765640
08/05/10 05:41 AM
08/05/10 05:41 AM
U.S.
U.S.
It was an exhaust on #8 . this pushrod has no marks on it!
Mopar Performance
Re: Trend pushrod failure [Re: moparniac] #765641
08/05/10 08:13 AM
08/05/10 08:13 AM
an8sec70cuda Offline
I'd call up Manton and order a good set.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Trend pushrod failure [Re: an8sec70cuda] #765642
08/05/10 09:15 AM
08/05/10 09:15 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Did ya check for piston to valve impact, to see if a exhaust valve hung?
Re: Trend pushrod failure [Re: an8sec70cuda] #765643
08/05/10 09:17 AM
08/05/10 09:17 AM
U.S.
U.S.
I am gonna talk to best machine and trend today and see what's up !!! I thought trend was the shyt.... I'm sorry but u cannot trust the rest of these pushrods!!! I have 2 different lengths and 2 extras but just can't trust them !!!
Mopar Performance
Re: Trend pushrod failure [Re: moparniac] #765644
08/05/10 10:05 AM
08/05/10 10:05 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
I'd start looking at the entire valvetrain before making any calls. How close do you run to spring coil bind? I'd throw an adjacent pushrod in the problem ho le and measure lift, watch trajectory during motion. Take a spring compressor (jesel-style) and see what addl. travel you have until C/B via the dial indicator. Get back with us. If you bought the parts seperately and married them together then, unfortunitly the burden of responsibility lies on you (the end builder).
Re: Trend pushrod failure [Re: HardcoreB] #765645
08/05/10 12:05 PM
08/05/10 12:05 PM
U.S.
U.S.
Well the heads/ pushrods / rockers and spring package all came from the same place all new !!! PtoV was .110 intake and .140 exhaust ... I'm not blaming Best Machine here one bit so no one twist that! They have contacted Trend and I am sending the whole lot to trend to be analyzed ... I have about 180 miles on my engine I believe it will be on my new odometer I installed. Once and if the pushrod was to blame we will go from there !!! Best Machine has been top notch to me from day one when I first bought all if this...
Mopar Performance
Re: Trend pushrod failure [Re: moparniac] #765646
08/05/10 12:53 PM
08/05/10 12:53 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
That to me looks like a brittle break - could be the steel was tempered wrong
Re: Trend pushrod failure [Re: DoubleD] #765647
08/05/10 01:22 PM
08/05/10 01:22 PM
St. Clair Shores, Michigan
bigsbigelow Offline
bigsbigelow  Offline
Ryan "Bigs" '73 Duster (BLKDUST) - Black, 100% factory sheet metal, flat hood, 346 cid, J Heads, and a bench seat. http://s268.photobucket.com/albums/jj1/bigsbigelow/ Best to date: 12.40 @ 109 mph
Re: Trend pushrod failure [Re: DoubleD] #765648
08/05/10 01:36 PM
08/05/10 01:36 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
I would tend to think its a break based o9n some some of meterial issue or during the heat treating process. I believe Trend buys there moly tubing in 21' lengths. ( maybe rolls but I dont think so) Once they determine what lengths they need. the tubing will go thru an annealing process. Thats usually about 1-2" from the finished end of the required tube length. I'd have to guess, they may find a problem in that arena. john is a good guy at Trend, and he will get you an answer for sure. It will be interesting to see what they find.
RIP Monte Smith
Re: Trend pushrod failure [Re: moparniac] #765649
08/05/10 03:14 PM
08/05/10 03:14 PM
I have seen Smith Bros. do the same thing, I had one break during a pull on the dyno, it broke the top off of a Crwoer roller lifter and ended up guaging the cam lobe On eof my freinds had the same thing happen on another set of Smith Bros but it broke at the very top under the ball cup end, mine had a defect in the material where it broke I now have Mantons in all of my motors, PM if you want a set. I'm a dealer for all three companys
Re: Trend pushrod failure [Re: HardcoreB] #765650
08/05/10 04:15 PM
08/05/10 04:15 PM
organ
maximum entropy Offline
organ
truer words were never spoken! i don't think i've ever seen a pushrod failure that wasn't due to some exogenous issue. check everything. betcha find a problem other than spontaneous failure.
Re: Trend pushrod failure [Re: Cab_Burge] #765651
08/06/10 02:56 PM
08/06/10 02:56 PM
U.S.
U.S.
sorry guys I had to walk away from frustration for a bit... anyways I sent the pushrods back to trend (thx to Best Machine for QUIK assistance) and no I didnt do any procedures mentioned about and NO I dont have one of them fancy LSM spring compressors... what I just went out and did with a air compressor is fill the cylinder with air it holds alot of pressure but it seeps air coming back out the o ring into the spark plug hole(cant get in there to tighten it hard)! when I disconnect the quik connect from the air line it blows back out a ton of air pressure and I imagine some will leak past the rings... also with the air line still attached I put my hand over both exhaust pipes (x pipe setup)and can feel no air coming out and put thin little strings over the pipe also and they are not moving so Im taking it piston didnt hit the valve here. thoughts and opinions welcome.... sorry its the only test I could do at the moment cause some requested I do so!
Mopar Performance
Re: Trend pushrod failure [Re: moparniac] #765652
08/06/10 04:17 PM
08/06/10 04:17 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
See if you can look thru the spark plug hole with a good bore scope , check the exhaust relief in the piston for a contact mark, You wont always bend a valve with piston to valve contact, We broke a push rod in the middle like that pic of yours, turned out to be a guide that was too tight, I ran this engine for 2 weeks on and off at the shop and it was fine, broke the push rod on the return road after the first pass, I ended up pullin the heads cause I couldn't find the problem, I bought a good bore scope the next day
Re: Trend pushrod failure [Re: emarine01] #765653
08/06/10 05:00 PM
08/06/10 05:00 PM
U.S.
U.S.
no bore scope here .... Im just gonna have to wait and see what trend says as they are gonna inspect them over! Its hard to believe a ptov contact (if the valve hung open like you said) wouldnt bend a valve but snap a thick "Trend" .135 wall HD pushrod so clean like that... youd think the valve would bend and pushrod bend before that happened to a "Trend" pushrod... should know something from Trend next week!
Mopar Performance
Page 1 of 3 1 2 3
