72' 360 car vs. truck motor #765502
08/04/10 08:50 PM
08/04/10 08:50 PM
Oshkosh WI
barrakudaman Offline OP
Oshkosh WI
There is a guy with a cheap 72' 360 for sale in my area. I want to build a stroker motor. Would a truck motor be a good start for the build? I dont know mileage, or condition yet. Thanks, Ken
Re: 72' 360 car vs. truck motor [Re: barrakudaman] #765503
08/04/10 09:00 PM
08/04/10 09:00 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Considering your buiding a stroker a 360 is a 360.
Re: 72' 360 car vs. truck motor [Re: barrakudaman] #765504
08/04/10 09:00 PM
08/04/10 09:00 PM
Az
Crizila Offline
Crizila  Offline
Az
Built my 408 from a 1971 360 from a motorhome. Aint broke it yet after 3 years of floging.
Fastest 300
Re: 72' 360 car vs. truck motor [Re: barrakudaman] #765505
08/04/10 10:10 PM
08/04/10 10:10 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
Sure, why not? The truck oil pan and pickup is different and the exhaust manifolds may be as well, but so what, it's unlikely that you'll reuse any of these parts anyway. If it were up to me about the only things I would be reusing would be the block, timing cover and depending on condition maybe the fuel pump eccentric. Everything else would be aftermarket.
Re: 72' 360 car vs. truck motor [Re: Crizila] #765506
08/04/10 10:17 PM
08/04/10 10:17 PM
Eastern,NC
68GTS383 Offline
68GTS383  Offline
Eastern,NC
Early truck engines came with a factory shot peened crank that is more desirable.The last three numbers of the part # is 640 and has an X embossed on one of the throws.A friend had a 640 tricked by a crank shop and shifts at 8800 RPM,runs 6.36 in 1/8 mile in a 69 Dart.That is with a Cast crank!
Re: 72' 360 car vs. truck motor [Re: 68GTS383] #765507
08/05/10 12:05 AM
08/05/10 12:05 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If he's building a stroker the crankshaft doesn't matter.
Re: 72' 360 car vs. truck motor [Re: stumpy] #765508
08/05/10 08:11 AM
08/05/10 08:11 AM
Oshkosh WI
Oshkosh WI
Thanks for the info.
