Re: 383 piston selection?
[Re: Banzaiii67]
#765127
08/05/10 01:42 AM
08/05/10 01:42 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
If you're using your orig. older 516 casting closed chamber heads, the KB400 (posted above) will give you roughly 10.25:1. They make a flat-top that will get you closer to 9:1. For a non-performance rebuild, that's where I'd prefer to be.
[Re: DusterKrazy]
#765131
08/05/10 12:51 PM
08/05/10 12:51 PM
Posts: 1,095 Bloomington, Illernoise
cptn60
Does the block require boring or is it within tolerance? There is a cheap solution with an early block for standard pistons only
This space available for rent
[Re: cptn60]
#765132
08/05/10 03:08 PM
08/05/10 03:08 PM
Posts: 130 Marcell, MN
68 Roadrunner
Marcell, MN
KB 400 pistons.
1968 Roadrunner 383 auto
.060 KB 400 domed pistons, Stealth heads, Torker intake, Holley 830, Lunati Voodoo cam 276/284, .513/.533, TCI 3500, 3.91 gears, all ARP fasteners,
[Re: CR8CRSHR]
#765134
08/05/10 03:35 PM
08/05/10 03:35 PM
Posts: 75,028 U.S.S.A.
JohnRR
U.S.S.A.
You all are forgetting the KB 162's. They won't get you the 10 + compression number you are looking for but with the 516 closed chambered heads and some work to them will get about 9.25 C/R. I have built 383's with that combo and been real happy...
No , I'm not forgetting that piece of crap , KB dropped the ball making that piston.
[Re: cptn60]
#765135
08/05/10 03:39 PM
08/05/10 03:39 PM
JohnRR
U.S.S.A.
KB 400 pistons.
Nope, 69 383 rr/magnum pistons. Positive deck(think stock 340) Really wakes up a 383.
Nope , that piston has a 1.932 CH which puts it .003 BELOW the deck on a blueprint 9.980 deck height . You have to cut the block .023 or more to get positive deck height on that particular year engine/piston combo, I have two untouched 69 383 HP engines, neither have the piston above the deck. Then for the OP to use a block like that with a closed chamber head he would need a .060 thick head gasket, no reason to cut the block to achieve positive deck , $$$$ machine work, only to run a thick custom head gasket , more $$$.
[Re: JohnRR]
#765136
08/06/10 11:17 AM
08/06/10 11:17 AM
cptn60
KB 400 pistons.
No John it really does give a positive deck on a 66 and earlier block. Hemi Harvester built one back in the mid 80's, And used some shaved 906s on it. Ran well. I'm doing one right now for my 66 Net sedan.
Ask Tom Hoover about it; it was in the old DC manual.
[Re: lokalik]
#765139
08/06/10 12:20 PM
08/06/10 12:20 PM
Posts: 303 Portland, OR
Banzaiii67
Portland, OR
oops... did i screw up 3 years ago? why is the 162 a pos?
It's not the piston itself, it is the design.
that piston has a 1.932 CH which puts it .003 BELOW the deck on a blueprint 9.980 deck height.
In layman's terms if you have a zero deck block and you use the 162 piston it will sit .024 in the hole no matter what you do. If you have open cambered heads like i do you'll end up with no more the 8.8 to 1 compression even with a steel shim head gasket.
[Re: Banzaiii67]
#765140
08/06/10 12:29 PM
08/06/10 12:29 PM
Posts: 388 Southington, Ohio
dm69charger
Southington, Ohio
Mine sit .040 in the hole. Block probably was not decked by previous owner. Terribly Compression ratio. Looking to stroke it since I will have it out and torn down.
[Re: dm69charger]
#765142
08/06/10 12:56 PM
08/06/10 12:56 PM
Banzaiii67
Portland, OR
That sucks man, I bought my motor from a guy who already had motor rebuilt by a reputable shop here locally. Supposedly it was 9:1, at least that is what he told me. I purchased it for $2200. A few weeks later, after doing the research on what i really had, i took the build paperwork to the place that rebuilt it, and asked them about the build, the owner helped him at the counter and looked at the paperwork and the specs. Come to find out that the guy who built it was no longer an employee of the shop and according to the notes, it appeared he also completely overlook the piston comp ht even though it was balanced and blueprinted. The good news even with 8.8 compression it still runs pretty hard, with a Comp XE274 cam and 3.73 gears and i can run 89 octane with no issues. The 440 source alum. heads or even some steel closed chamber heads would solve a lot of issues, just wish i did it before i put the motor in the car.
[Re: cptn60]
#765143
08/06/10 04:17 PM
08/06/10 04:17 PM
JohnRR
U.S.S.A.
KB 400 pistons.
Sorry , there is no way that can happen , the numbers don't lie , unless a 66 383 has a shorter deck height than a later 383? The .020 over deck height is the NHRA blueprint spec and you have to build a 68-69 383 to NHRA spec to get the factory advertised 10.0 compression ratio , that's piston .020 above the deck and the head cc at 79.5 , I've yet to cc a 906 under 90 cc .
I'll save you the trouble here is the math.
1.932 CH 6.358 rod 3.375/2= 1.6875 stroke
1.932 + 6.358 + 1.6875 = 9.9775
9.9775 - 9.980 = -0.0025
Ok I was wrong , my 56k mile original 69 383 HP in my original 69 Dart GTS had a piston .003 in the hole so the deck on that block is actually .0005 over stock , I screwed up my math at some point thinking a stock piston was .003 in the hole.
[Re: ademon]
#765144
08/06/10 04:23 PM
08/06/10 04:23 PM
JohnRR
U.S.S.A.
This may be a dumb question so sorry, but why cant someone just copy the stock 383 hp flat top piston and maybe add very small 2/3ish cc valve pockets, so when you deck the block to clean and say mill your 906 heads 20 or 30thou you will end up with 9.5 + with a flat top. my stock bottom end 383 hp has flat tops that sit at about zero and with 80cc 915's and a .039 gasket CR ended up at 9.8 ??
Because the aftermarket thinks that every 383 that exists has already been decked .010 or more , the closest currently available pistons are the speed pro L2315F flat top at 1.920 with no valve reliefs or a Diamond at 1.916 but the Diamond at least has valve reliefs , but you lose compression with the 4cc relief .
I'm currently building a Pure Stock Drags legal 383 using a semi custom Diamond piston , it will have a 1.935ish CH, because my block has already been decked .025 because I zero decked it for speed pros and the shop that did it screwed up and it had to be trimmed more, with no valve reliefs and a set of 906's cut to 80 cc .
