cometic gasket oil leaks
#764799
08/03/10 09:30 PM
08/03/10 09:30 PM
Posts: 182 usa
demon454
usa
Having an oil leak out of right rear head with cometic gaskets anyone else have this issue?Are they known to leak oil?This is a small block by the way.
Re: cometic gasket oil leaks
[Re: demon454]
#764800
08/03/10 10:00 PM
08/03/10 10:00 PM
Posts: 425 OH, USA
GORacing
super street
super street
OH, USA
Yes mine always leaked. I ran a thin bead along the lifter valley and down the back of the block. I mean thin. Then I did the same on the head side of the gasket. IT was more of a smear then a bead, but it worked. I'd never use them again.
74 Roadrunner
360 cid on alky
best 60' 1.442
best ET 10.820 @ 123.23
[Re: demon454]
#764802
08/04/10 10:08 PM
08/04/10 10:08 PM
Posts: 425 OH, USA
GORacing
super street
super street
OH, USA
You can use them but if the surface isn't to the finish they require ... they will leak unless you use a sealant.
74 Roadrunner
360 cid on alky
best 60' 1.442
[Re: rebel]
#764804
08/06/10 01:48 AM
08/06/10 01:48 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
No leaks on my Big Block...but seap a little oil on the front corner of my small block..not enough to get worried about.
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
