cometic gasket oil leaks #764799
08/03/10 09:30 PM
08/03/10 09:30 PM
usa
demon454 Offline OP
demon454  Offline OP
usa
Having an oil leak out of right rear head with cometic gaskets anyone else have this issue?Are they known to leak oil?This is a small block by the way.
Re: cometic gasket oil leaks [Re: demon454] #764800
08/03/10 10:00 PM
08/03/10 10:00 PM
OH, USA
GORacing Offline
super street
GORacing  Offline
super street
OH, USA
Yes mine always leaked. I ran a thin bead along the lifter valley and down the back of the block. I mean thin. Then I did the same on the head side of the gasket. IT was more of a smear then a bead, but it worked. I'd never use them again.
74 Roadrunner 360 cid on alky best 60' 1.442 best ET 10.820 @ 123.23
Re: cometic gasket oil leaks [Re: GORacing] #764801
08/03/10 10:27 PM
08/03/10 10:27 PM
usa
demon454 Offline OP
demon454  Offline OP
usa
I run nos what gasket should i switch to then?
Re: cometic gasket oil leaks [Re: demon454] #764802
08/04/10 10:08 PM
08/04/10 10:08 PM
OH, USA
GORacing Offline
super street
GORacing  Offline
super street
OH, USA
You can use them but if the surface isn't to the finish they require ... they will leak unless you use a sealant.
Re: cometic gasket oil leaks [Re: GORacing] #764803
08/05/10 05:28 PM
08/05/10 05:28 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
if you have your surfaces machined smooth enough you'll be fine. i re-used a set 9 times before i developed a leak. just bought new embosed shims to replace the old ones & we were good to go again.
Re: cometic gasket oil leaks [Re: rebel] #764804
08/06/10 01:48 AM
08/06/10 01:48 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
No leaks on my Big Block...but seap a little oil on the front corner of my small block..not enough to get worried about.
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
