trans pan gasket #763555
08/02/10 03:30 PM
08/02/10 03:30 PM
minnesota
P
president61 Offline OP
P
minnesota
I bought a aluminum trans pan for the coronet. whats the best kind of gasket to use. i'm sick of the leaks. thanks
Re: trans pan gasket [Re: president61] #763556
08/02/10 03:44 PM
08/02/10 03:44 PM
okla.
O
okie Offline
okie  Offline
O
okla.
I went to my local dealer and got 1 of the hard gaskets with the seals on each side of it. It was the only way I got mine fixed. Ronnie
Re: trans pan gasket [Re: okie] #763557
08/02/10 04:41 PM
08/02/10 04:41 PM
NY usa
540challenger Offline
NY usa
Thats what i use her eis a link to the parts numbers.
http://www.moparts.org/Tech/Archive/auto/25.html
Also i have used the cheap ones that come with the filter and never had a problems as long as the pan rails are good.
Re: trans pan gasket [Re: president61] #763558
08/02/10 04:56 PM
08/02/10 04:56 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
HECK ....a good cast alum pan ...with a nice straight and FLAT pan rail should be GOOD NUFF with a cheapO cork gasket !
Re: trans pan gasket [Re: dOoC] #763559
08/02/10 05:06 PM
08/02/10 05:06 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
teah a cheap o will work but the new gaskets from the dealer will never shrink get lose and it is the last gasket you will ever buy.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: trans pan gasket [Re: dOoC] #763560
08/02/10 06:24 PM
08/02/10 06:24 PM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Those things wick like a candle.
Re: trans pan gasket [Re: Commando1] #763561
08/02/10 09:41 PM
08/02/10 09:41 PM
minnesota
P
P
minnesota
thanks for all of the input
