Torqueing lock nut on Band adjustment for on 727 #762940
08/01/10 05:34 PM
08/01/10 05:34 PM
Berwyn, IL
challenger70 Offline OP
Berwyn, IL
Is there a trick to torqueing the lock nut to the 30ft-lbs but not moving the adjusting bolt after it's adjusted properly? would a crows foot work? What is the chrysler special tool for this?
Re: Torqueing lock nut on Band adjustment for on 727 [Re: challenger70] #762941
08/01/10 06:09 PM
08/01/10 06:09 PM
YES Easy does it or the stud will break off--snug it good with a short wrench--never has one come loose but lots break off from Gorilla mechanics
Re: Torqueing lock nut on Band adjustment for on 727 [Re: ] #762942
08/01/10 07:44 PM
08/01/10 07:44 PM
Berwyn, IL
Berwyn, IL
I am trying to be precise w/ the torque wrench but as you turn the lock nut, so turns the adjusting bolt...
Re: Torqueing lock nut on Band adjustment for on 727 [Re: challenger70] #762943
08/01/10 07:46 PM
08/01/10 07:46 PM
Andrewh Offline
Andrewh  Offline
you have to have two hands and two wrenches in there to hold it in place while you turn the lock nut.
Re: Torqueing lock nut on Band adjustment for on 727 [Re: Andrewh] #762944
08/01/10 07:47 PM
08/01/10 07:47 PM
Berwyn, IL
Berwyn, IL
So you just "guess" as to the torque? it's supposed to be 30ft-lbs per the service manual, is it not that important?
Re: Torqueing lock nut on Band adjustment for on 727 [Re: challenger70] #762945
08/01/10 07:57 PM
08/01/10 07:57 PM
Az
Crizila Offline
Crizila  Offline
Az
Right - not that important.
Fastest 300
Re: Torqueing lock nut on Band adjustment for on 727 [Re: Crizila] #762946
08/01/10 09:31 PM
08/01/10 09:31 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I have benn building TF for 25 years and have never used a torque wrench on the jam nut.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Torqueing lock nut on Band adjustment for on 727 [Re: dusturbd340W5] #762947
08/01/10 11:18 PM
08/01/10 11:18 PM
Florida STAYcation
dOc … Offline
The village idiot's idiot
dOc …  Offline
Florida STAYcation
..... me FORTY years
Re: Torqueing lock nut on Band adjustment for on 727 [Re: dOc …] #762948
08/02/10 02:09 AM
08/02/10 02:09 AM
Berwyn, IL
Berwyn, IL
Ok, thanks
Re: Torqueing lock nut on Band adjustment for on 727 [Re: challenger70] #762949
08/02/10 02:38 AM
08/02/10 02:38 AM
have the nut/bolt threads clean/put some Loctite on it/snug it up!
Re: Torqueing lock nut on Band adjustment for on 727 [Re: RapidRobert] #762950
08/02/10 02:51 AM
08/02/10 02:51 AM
Florida STAYcation
dOc … Offline
dOc …  Offline
Florida STAYcation
LOCKtite ? ... ...
You must have some BUMPY ROADS in Nebraska !!
Re: Torqueing lock nut on Band adjustment for on 727 [Re: dOc …] #762951
08/02/10 03:05 AM
08/02/10 03:05 AM
Doc you're still awake
Re: Torqueing lock nut on Band adjustment for on 727 [Re: RapidRobert] #762952
08/02/10 03:17 AM
08/02/10 03:17 AM
Florida STAYcation
dOc … Offline
dOc …  Offline
Florida STAYcation
NOPE ...I beez typimng in my sleep ... .....zzzzzzzz ...
Re: Torqueing lock nut on Band adjustment for on 727 [Re: challenger70] #762953
08/02/10 10:18 AM
08/02/10 10:18 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Ive never torqued the lock nut either.The square sockets are avaliable from Sears, Snapon etc.I have a few in the garage as my 58 Harley also uses the square drive to adjust the rear brake shoes.Rocky
Chrysler Firepower
