Re: who's got the best 440 dampner?
[Re: Deepockets]
#762670
08/01/10 11:01 AM
08/01/10 11:01 AM
Posts: 705 Michigan
Hemiroid
pro's con's on the best dampner for 528ci new build drag engine with jessel drive. some where i heard that some crankshaft company would not warrenty there crank is you used a certain brand. if thats so i dont think i'd go that way. please share your experiances
ATI hands down.
[Re: Hemiroid]
#762671
08/01/10 11:04 AM
08/01/10 11:04 AM
Posts: 12,339 somwhere
smokinwoody
somwhere
ATI hands down.
[Re: bigtimeauto]
#762676
08/01/10 01:07 PM
08/01/10 01:07 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
ATI on all my power and higher end builds, Powerbond SFI for everyday bracket and street/strip builds.
ATI is proven stuff that is available, very adaptable and flat out works.
RIP Monte Smith
[Re: Thumperdart]
#762683
08/02/10 11:09 AM
08/02/10 11:09 AM
Posts: 19,379 Las Vegas
Al_Alguire
Las Vegas
In case it has not sunk in ATI!
[Re: FastmOp]
#762684
08/02/10 11:24 AM
08/02/10 11:24 AM
Posts: 12,013 Finally a HUSKER again
Moparnut426
ATI, here aslo!
I was told by a well known engine builder that the ATI is the best damper because they are accurate throughout the rpm. Fluid Dampers are good for low RPM, Diesel engines accually. Some diesel mfgs run fluid dampers on their OEM engines. My machinist spun my old Fluid damper for my 360 build, and he told me it was wacky, would spinn up ok 1 time, then be way off the other time, then be only a little bit another time. I bought an OEM 340 damper for it, and it was nuts on. For my 408 build, I did a bunch of reserch, and the ATI is what I found was the most accurate.
Kasey
[Re: Deepockets]
#762686
08/02/10 12:37 PM
08/02/10 12:37 PM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
I have an ATI on my hemi and a Fluidampr on my wedge. No complaints about either one.
[Re: an8sec70cuda]
#762687
08/02/10 12:54 PM
08/02/10 12:54 PM
Posts: 976 Woodstock , Georgia
Mopar_racer_99
Woodstock , Georgia
I have had fluidampr and ATI, only problem with ATI it needs to be rebuilt every other year if making under 900 hp or every year if over, Elastomer breaks down. That is realworld results and also what ATI will tell you. John
8.72 @ 154.6 ,68 Charger 578ci 440-1s, 3000# w/drvr, 2150 den/alt NA
