who's got the best 440 dampner? #762669
08/01/10 10:47 AM
08/01/10 10:47 AM
glendora, ca.
Deepockets Offline OP
glendora, ca.
pro's con's on the best dampner for 528ci new build drag engine with jessel drive. some where i heard that some crankshaft company would not warrenty there crank is you used a certain brand. if thats so i dont think i'd go that way. please share your experiances
Re: who's got the best 440 dampner? [Re: Deepockets] #762670
08/01/10 11:01 AM
08/01/10 11:01 AM
Hemiroid Offline
Hemiroid  Offline
ATI hands down.
Re: who's got the best 440 dampner? [Re: Hemiroid] #762671
08/01/10 11:04 AM
08/01/10 11:04 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
ATI hands down.
Re: who's got the best 440 dampner? [Re: smokinwoody] #762672
08/01/10 12:20 PM
08/01/10 12:20 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
ATI hands down.
Mopar Performance
Re: who's got the best 440 dampner? [Re: moparniac] #762673
08/01/10 12:31 PM
08/01/10 12:31 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
ATI X4
Re: who's got the best 440 dampner? [Re: Deepockets] #762674
08/01/10 12:33 PM
08/01/10 12:33 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Fluidamper............x10
Re: who's got the best 440 dampner? [Re: moparniac] #762675
08/01/10 12:56 PM
08/01/10 12:56 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
ATI hands down.
X 1000000000000000000000
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: who's got the best 440 dampner? [Re: bigtimeauto] #762676
08/01/10 01:07 PM
08/01/10 01:07 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
ATI on all my power and higher end builds, Powerbond SFI for everyday bracket and street/strip builds.
ATI is proven stuff that is available, very adaptable and flat out works.
RIP Monte Smith
Re: who's got the best 440 dampner? [Re: Deepockets] #762677
08/01/10 01:35 PM
08/01/10 01:35 PM
I bought and used a Fluid Dampener on my 528, 4.375 stroke. I bought and used a ATI on my 512 (4.250 stroke) street motor and again when I switch cranks to increase the compression on the 4.3 stroke crank. I have now decided to only use ATI on all of my motors, steel or steel and aluminum ATI all the way
Re: who's got the best 440 dampner? [Re: Cab_Burge] #762678
08/01/10 01:38 PM
08/01/10 01:38 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
ATI !
Re: who's got the best 440 dampner? [Re: VernMotor] #762679
08/01/10 02:04 PM
08/01/10 02:04 PM
glendora, ca.
glendora, ca.
wow! sounds like ati wins the poll. it looks as if thats the way im going, thanks
Re: who's got the best 440 dampner? [Re: Deepockets] #762680
08/01/10 02:30 PM
08/01/10 02:30 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
ATI here as well if your still on the fence.
It's lighter then my fluidamper under the workbench.
Re: who's got the best 440 dampner? [Re: Deepockets] #762681
08/01/10 06:00 PM
08/01/10 06:00 PM
Peru
cbarracuda Offline
cbarracuda  Offline
Peru
heres some good info from a crank company:
"2. DAMPERS WITH MOVING INERTIA WEIGHTS
A. Fluid, balls, springs, inertia rings with rubber O-Rings, etc. Can
you balance a wheel on your race car if the tires are flat???? How
can your rotating assembly be balanced if to quote one
manufacturer, “These units (Dampers) should not be on the crank
for balancing as the inertia weight may not be centered until the
engine starts.” NEWS FLASH!!!! Centrifugal force will always take
the inertia weight off center no matter what RPM. Your assembly
is never balanced. TELL TALE SIGN!!!! Metal transferred on nose
outside diameter and damper internal diameter . . . A fatigue crack
starts. SNAP!!!! The crank breaks"
Re: who's got the best 440 dampner? [Re: Deepockets] #762682
08/02/10 10:52 AM
08/02/10 10:52 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
What's the deal w/ having to use spacers or whatever to make sure the pulleys are all aligned when using an ATI damper? I've never been sure exactly what the deal is w/ that...
Re: who's got the best 440 dampner? [Re: Thumperdart] #762683
08/02/10 11:09 AM
08/02/10 11:09 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
In case it has not sunk in ATI!
Re: who's got the best 440 dampner? [Re: FastmOp] #762684
08/02/10 11:24 AM
08/02/10 11:24 AM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
ATI, here aslo!
I was told by a well known engine builder that the ATI is the best damper because they are accurate throughout the rpm. Fluid Dampers are good for low RPM, Diesel engines accually. Some diesel mfgs run fluid dampers on their OEM engines. My machinist spun my old Fluid damper for my 360 build, and he told me it was wacky, would spinn up ok 1 time, then be way off the other time, then be only a little bit another time. I bought an OEM 340 damper for it, and it was nuts on. For my 408 build, I did a bunch of reserch, and the ATI is what I found was the most accurate.
Kasey
Re: who's got the best 440 dampner? [Re: BradH] #762685
08/02/10 12:32 PM
08/02/10 12:32 PM
Canada
CrAzYMoPaRGuY Online content
CrAzYMoPaRGuY  Online Content
Canada
I have an ATI on my Hemi, I found the damper was farther out than a stock damper, I had to fabricate a mount for my alternator anyways so it wasn't a problem, but the waterpump pulley had to be spaced out from the front of the engine... I have elephant ears and I think I used a 1/4" or 1/2" spacer inside the waterpump pulley, can't remember which....
CrAzYMoPaRGuY
Re: who's got the best 440 dampner? [Re: Deepockets] #762686
08/02/10 12:37 PM
08/02/10 12:37 PM
an8sec70cuda Offline
I have an ATI on my hemi and a Fluidampr on my wedge. No complaints about either one.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: who's got the best 440 dampner? [Re: an8sec70cuda] #762687
08/02/10 12:54 PM
08/02/10 12:54 PM
Woodstock , Georgia
Mopar_racer_99 Offline
Woodstock , Georgia
I have had fluidampr and ATI, only problem with ATI it needs to be rebuilt every other year if making under 900 hp or every year if over, Elastomer breaks down. That is realworld results and also what ATI will tell you. John
8.72 @ 154.6 ,68 Charger 578ci 440-1s, 3000# w/drvr, 2150 den/alt NA
Re: who's got the best 440 dampner? [Re: Mopar_racer_99] #762688
08/02/10 01:17 PM
08/02/10 01:17 PM
Canada
RobR Offline
RobR  Offline
Canada
Innovators..!!
