Re: who's got the best 440 dampner?
[Re: Deepockets]
#762670
08/01/10 11:01 AM
08/01/10 11:01 AM
Posts: 705 Michigan
Hemiroid
pro's con's on the best dampner for 528ci new build drag engine with jessel drive. some where i heard that some crankshaft company would not warrenty there crank is you used a certain brand. if thats so i dont think i'd go that way. please share your experiances
ATI hands down.
[Re: Hemiroid]
#762671
08/01/10 11:04 AM
08/01/10 11:04 AM
Posts: 12,339 somwhere
smokinwoody
somwhere
ATI hands down.
[Re: bigtimeauto]
#762676
08/01/10 01:07 PM
08/01/10 01:07 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
ATI on all my power and higher end builds, Powerbond SFI for everyday bracket and street/strip builds.
ATI is proven stuff that is available, very adaptable and flat out works.
RIP Monte Smith
[Re: Thumperdart]
#762683
08/02/10 11:09 AM
08/02/10 11:09 AM
Posts: 19,361 Las Vegas
Al_Alguire
Las Vegas
In case it has not sunk in ATI!
[Re: FastmOp]
#762684
08/02/10 11:24 AM
08/02/10 11:24 AM
Posts: 12,008 Finally a HUSKER again
Moparnut426
ATI, here aslo!
I was told by a well known engine builder that the ATI is the best damper because they are accurate throughout the rpm. Fluid Dampers are good for low RPM, Diesel engines accually. Some diesel mfgs run fluid dampers on their OEM engines. My machinist spun my old Fluid damper for my 360 build, and he told me it was wacky, would spinn up ok 1 time, then be way off the other time, then be only a little bit another time. I bought an OEM 340 damper for it, and it was nuts on. For my 408 build, I did a bunch of reserch, and the ATI is what I found was the most accurate.
Kasey
[Re: Deepockets]
#762686
08/02/10 12:37 PM
08/02/10 12:37 PM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
I have an ATI on my hemi and a Fluidampr on my wedge. No complaints about either one.
[Re: an8sec70cuda]
#762687
08/02/10 12:54 PM
08/02/10 12:54 PM
Posts: 976 Woodstock , Georgia
Mopar_racer_99
Woodstock , Georgia
I have had fluidampr and ATI, only problem with ATI it needs to be rebuilt every other year if making under 900 hp or every year if over, Elastomer breaks down. That is realworld results and also what ATI will tell you. John
8.72 @ 154.6 ,68 Charger 578ci 440-1s, 3000# w/drvr, 2150 den/alt NA
[Re: RobR]
#762689
08/02/10 02:39 PM
08/02/10 02:39 PM
Don't leave out the part about ATI having several BB Mopar units--duh..which one? Different hub lengths --some will clear timing cover, some won't clear certain ones etc big PIA and the big deal with ATI is that they send them out from the factory too small on the ID--with all the different brands of cranks and the small side on the ID you usually have to have a shop HONE the indside for decent fit--yea they need to be tight but not THAT tight--measure before you go to install--if someone says they fit easy they had a China crank with the snout on the small side of spec..also ATI's run with no pulleys NEED BOLTS in the pulley holes per ATI instructions or they can come apart---READ the instructions and CALL them as they have enough choices to get you in the weeds with a quickie order.
[Re: 70blackfish]
#762691
08/02/10 03:25 PM
08/02/10 03:25 PM
BradH
There's part of my confusion w/ ATI...
ATI makes a 2 ring and 3 ring the 2 ring fits on without a spacer...
... and there's the other part, especially after I heard that the 2-ring doesn't work as well and the only reason for the 2-ring was to make an ATI that fit w/ any other modifications.
[Re: dOc !]
#762693
08/02/10 06:08 PM
08/02/10 06:08 PM
DragtimeDodge
I just published a piece about this topic entitled "Crankshaft Vibration Dampers 101" at The Dragtime News, along with other newly added items. Hope you like it. Bob Beucler DRAGTIME 1964 Dodge Polara www.DragtimeNews.com
[Re: DragtimeDodge]
#762695
08/02/10 06:17 PM
08/02/10 06:17 PM
Posts: 1,169 Virginia Beach, VA
Old School
Virginia Beach, VA
i have fluid dampners in all of my motors.never any problems.i was told the engine sees the fluid dampner weight as alot lighter than it's static weight.
68 cuda formula S 588" bb 5sp 70 CUDA CONVERT 500" 5SP (SUBLIME) 70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
