?? 2 speed wiper motor, 3 speed switch ?? #762617
08/01/10 07:49 AM
08/01/10 07:49 AM
Pittsfield, Mass.
Russ_Davis Offline OP
Pittsfield, Mass.
Will this work untill I get the right parts?
Re: ?? 2 speed wiper motor, 3 speed switch ?? [Re: Russ_Davis] #762618
08/01/10 08:55 AM
08/01/10 08:55 AM
Montreal,Quebec,Canada
JulesdaWiperman Offline
super gas
super gas
No it won't and the opposite is also true.
Jules
Re: ?? 2 speed wiper motor, 3 speed switch ?? [Re: JulesdaWiperman] #762619
08/01/10 09:51 AM
08/01/10 09:51 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Jules:
In your experience have you found that the wiring harness is the same for both the 2 and 3 speed? In other words, if the switch and motor were replaced, would it be a "plug 'n play"
Re: ?? 2 speed wiper motor, 3 speed switch ?? [Re: Commando1] #762620
08/01/10 10:10 AM
08/01/10 10:10 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Jules:
I'm not Jules but the answer is yes .
Re: ?? 2 speed wiper motor, 3 speed switch ?? [Re: JohnRR] #762621
08/01/10 06:26 PM
08/01/10 06:26 PM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
i was wondering that also, but i don't know what wires go to two of the male connections:
Re: ?? 2 speed wiper motor, 3 speed switch ?? [Re: 68KillerBee] #762622
08/01/10 06:37 PM
08/01/10 06:37 PM
MA
440beeper Offline
440beeper  Offline
MA
This seems to be a fairly common conversion (I'll be doing the same soon enough)... maybe this should be something for the tech archives?
Re: ?? 2 speed wiper motor, 3 speed switch ?? [Re: JohnRR] #762623
08/01/10 10:02 PM
08/01/10 10:02 PM
ontario calif
N
ns1aar Online content
ns1aar  Online Content
N
ontario calif
Jules:
The variable switch and the 3spd switch have different plugs
NS1AAR
Re: ?? 2 speed wiper motor, 3 speed switch ?? [Re: Russ_Davis] #762624
08/01/10 10:30 PM
08/01/10 10:30 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
What car do you need a switch for?
Re: ?? 2 speed wiper motor, 3 speed switch ?? [Re: ns1aar] #762625
08/02/10 09:41 AM
08/02/10 09:41 AM
Commando1 Offline
Commando1  Offline
Jules:
I know that. I asked because many times the harnesses are universal and can accomodate either. You see harnesses with a zillion unused connectors hanging out unused all the time.
Re: ?? 2 speed wiper motor, 3 speed switch ?? [Re: Commando1] #762626
08/02/10 11:14 AM
08/02/10 11:14 AM
NW Indiana
deansrr Offline
deansrr  Offline
NW Indiana
no it doesn't work, found out the hard way, someone changed either the switch or motor at some time and took a little while to figure it out.
1973 Road Runner 1974 Satellite (for sale) 1973 240z (wifes) 1993 Ramcharger (thanks Devil) 2002 Honda S2000
Re: ?? 2 speed wiper motor, 3 speed switch ?? [Re: deansrr] #762627
08/03/10 10:35 AM
08/03/10 10:35 AM
super gas
super gas
This thread still does not mention year and model of car.
More info please.
Jules
Re: ?? 2 speed wiper motor, 3 speed switch ?? [Re: JulesdaWiperman] #762628
08/03/10 01:27 PM
08/03/10 01:27 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
More info please.
Jules
What , you're not a mind reader ? Of course that info is not mentioned , complete info when people ask questions is hardly ever given , you have to it out of them.
Re: ?? 2 speed wiper motor, 3 speed switch ?? [Re: ns1aar] #762629
08/03/10 01:29 PM
08/03/10 01:29 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Jules:
Much like myself you are ASSuMEing the type of car, But the sreen name of the person that asked the question tells me he has a 68 B body so I felt confident answering his question. 68-70 B body there is no separate dash harness for 2 speed or 3 speed so it's pretty much PLUG n PLAY as asked if you have the correct parts.
Re: ?? 2 speed wiper motor, 3 speed switch ?? [Re: 68KillerBee] #762630
08/03/10 01:29 PM
08/03/10 01:29 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
A jumper wire goes between them.
Re: ?? 2 speed wiper motor, 3 speed switch ?? [Re: JohnRR] #762631
08/03/10 02:11 PM
08/03/10 02:11 PM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
Thanks JohnRR. I ended up saying screw it and put it all back together. Will have to wait until I redo my tic-toc-tac to mess with all that again.
Re: ?? 2 speed wiper motor, 3 speed switch ?? [Re: 68KillerBee] #762632
08/03/10 06:34 PM
08/03/10 06:34 PM
Pittsfield, Mass.
Pittsfield, Mass.
Thanks for covering for me John. Its a 71 Roadrunner. I purchaced a dash harness and complete gauge cluster. The car has a 2 speed motor and I have a 3 speed switch. I guess I'll get a 2 speed switch, but the harness fits the 3 speed switch. I getting from this that the harness will work for both??
Re: ?? 2 speed wiper motor, 3 speed switch ?? [Re: Russ_Davis] #762633
08/03/10 08:11 PM
08/03/10 08:11 PM
super gas
super gas
You will need a motor like this.
Jules
Re: ?? 2 speed wiper motor, 3 speed switch ?? [Re: JulesdaWiperman] #762634
08/03/10 08:12 PM
08/03/10 08:12 PM
super gas
super gas
Your dash wiring plugs must be like this.
Jules
Re: ?? 2 speed wiper motor, 3 speed switch ?? [Re: JulesdaWiperman] #762635
08/03/10 08:14 PM
08/03/10 08:14 PM
super gas
super gas
You need this type of cam arm.
Re: ?? 2 speed wiper motor, 3 speed switch ?? [Re: JulesdaWiperman] #762636
08/03/10 08:15 PM
08/03/10 08:15 PM
super gas
super gas
You need to convert your linkage to a 3 speed connection like this.
