440 timing #762088
07/31/10 02:21 PM
07/31/10 02:21 PM
United states wisconsin
bigblockbryan Offline OP
should i time my 440 with a light and what were is peak performance on a 440.10.1. comp 484 cam alummium intake dual plane intake and 750 carb thanks.bryan
Re: 440 timing [Re: bigblockbryan] #762089
07/31/10 03:17 PM
07/31/10 03:17 PM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
You need a timing light AND a vacuum gauge.
A book on how to do a tune-up wouldn't hurt either.
Get these first and then we'll lead you through the process.
Re: 440 timing [Re: Commando1] #762090
07/31/10 03:27 PM
07/31/10 03:27 PM
Watertown, WI
MikeyT Offline
MikeyT  Offline
Watertown, WI
I use a dial back light and have been able to find that mine likes about 17 initial with a total of 38, similar 440.
Yet, like people stated on here, it would be good to get a nice tuning book.
Mike
1969 Dodge Dart Swinger
Re: 440 timing [Re: MikeyT] #762091
07/31/10 03:34 PM
07/31/10 03:34 PM
Commando1 Offline
Commando1  Offline
I use a dial back light and have been able to find that mine likes about 17 initial with a total of 38, similar 440. Mike
If the lad is asking on whether he should use a timing light, he has no idea WTH you are talking about.
I'm just going to sit back and watch the zillion replies telling him all about advanced tuning theory before he even has the tools.
Re: 440 timing [Re: Commando1] #762092
07/31/10 04:51 PM
07/31/10 04:51 PM
Watertown, WI
MikeyT Offline
MikeyT  Offline
Watertown, WI
LOL ok, good point. I got excited to help out and jumped ahead. A good timing light can be picked up from sears for around 45 bucks and a vaccum guage is a must to set it right.
Of course if your somewhere near Madison Wisconsin, I could you these tools until you get them and show you how to set it and get it running nice!
Mike
Re: 440 timing [Re: Commando1] #762093
07/31/10 08:05 PM
07/31/10 08:05 PM
Jorsey
P
Polaraco Offline
Polaraco  Offline
P
Jorsey
Black Sheep. . . .
Re: 440 timing [Re: Polaraco] #762094
07/31/10 09:40 PM
07/31/10 09:40 PM
yes i will buy a gauge and a light also i forgot to mention im running only 2 inch exaust. wich is probably most of the problem so next weekend i will be pulling it off and building a 3 inch for it.
Re: 440 timing [Re: bigblockbryan] #762095
07/31/10 09:50 PM
07/31/10 09:50 PM
San Gabriel, CA 91775
rexus31 Offline
rexus31  Offline
What does the exhaust tube diameter have to do with timing the motor?
2007 Dodge Charger R/T, Road and Track Performance Group, Steel Blue 1965 Chrysler 300 Convertible, 383 4V, 727TF, Factory Air, Spanish Red 1964 Pontiac GTO, Tri-Power, 4 Speed, Grenadier Red "What ain't no country I ever heard of. They speak English in What?" - Jules Winnfield
Re: 440 timing [Re: rexus31] #762096
07/31/10 09:57 PM
07/31/10 09:57 PM
well i can get it really close by ear and it sounds great then when i take it out run it it it doesnt seem like it performs correcty. there is were the restictive exaust comes in also i should have rejetted the carb when i threw the pipes on too im just thinking hey once in my life i will try a light on it
Re: 440 timing [Re: bigblockbryan] #762097
08/01/10 01:06 AM
08/01/10 01:06 AM
rexus31 Offline
rexus31  Offline
Unbelievable. You can't time a motor by ear.
Re: 440 timing [Re: rexus31] #762098
08/01/10 01:26 AM
08/01/10 01:26 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Sounds right versus is right can be totally different. What a lot of guys don't realize is that a distributor is a lot like a carb, it NEEDS to be tuned for your application. If you're just slapping one on and going, you are leaving performance on the table. A distributor needs a correct advance curve for your motor, one of the other posters got into this a little bit a few posts up. If that's right over your head don't just ignore it, because without a properly dialed in distributor your motor will not reach its peak performance or driveability.
Re: 440 timing [Re: DaytonaTurbo] #762099
08/01/10 02:42 AM
08/01/10 02:42 AM
yea i relize this so getting a tune up book some mentioned earlier.Is there anyone thats better then the other im planing on getting a light and gauge later this week.then do some thrashing again next weekend
Re: 440 timing [Re: bigblockbryan] #762100
08/01/10 01:00 PM
08/01/10 01:00 PM
get a dial back light. they ain't as accurate as a good basic Sears non dialback unit cause the delay is based on time and different harmonic balancers of different makes are different and they sure ain't calibrated at their factory for Mopar 7&1/4" dia balancers but they're good within 1 degree (mine was) & that's pretty good and supposedly MSD's play havoc w them but they are SO much fun to play with. Disregard the above information overload and get a fairly good one & have fun
Re: 440 timing [Re: RapidRobert] #762101
08/01/10 03:20 PM
08/01/10 03:20 PM
Watertown, WI
MikeyT Offline
MikeyT  Offline
Watertown, WI
Here is a way to read vaccum gauges! I thought it was extremely helpful.
http://www.secondchancegarage.com/public/186.cfm
mike
Re: 440 timing [Re: MikeyT] #762102
08/06/10 03:45 AM
08/06/10 03:45 AM
bought a timing light at sears gonna try and figure it out it was there digital once have access to a annalog also
