Help with hood adjustment #761938
07/31/10 10:03 AM
07/31/10 10:03 AM
Kentucky, USA
derekeh Offline OP
derekeh  Offline OP
Kentucky, USA
I dont know if my hood hinges are worn out or if I need to adjust something. I have the hood lined up fine all the way around. Just when I go down the road the hood will raise up all around like a half inch. Does this just mean my hinges are worn out or what?
Re: Help with hood adjustment [Re: derekeh] #761939
07/31/10 12:46 PM
07/31/10 12:46 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Where is it raising up, in a back corner? Have you tried adjusting the hood and hinge a bit further downward?
Re: Help with hood adjustment [Re: DaytonaTurbo] #761940
07/31/10 12:58 PM
07/31/10 12:58 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
If it's raising up in the rear then the hinges need replaced or rebuilt.
Re: Help with hood adjustment [Re: Neil] #761941
07/31/10 07:19 PM
07/31/10 07:19 PM
Kentucky, USA
derekeh Offline OP
derekeh  Offline OP
Kentucky, USA
its raising up in the rear both sides
Re: Help with hood adjustment [Re: derekeh] #761942
08/01/10 09:29 AM
08/01/10 09:29 AM
Wattsburg, Pa
Dr V Offline
Dr V  Offline
Wattsburg, Pa
You need hinges. Next step is chipping paint on the edges. Ive done it twice. SMS is the place to go.
69 1/2 A12 BEE 4 spd
1968 Charger 383
1970 Roadrunner 440+6 Survivor
2019 Redeye
2005 FORD GT Red/White
2017 Viper ACR Extreme Red/White
1979 Branco Red/Red
2018 Porsche GT3 Miami
1971 440+6 Cuda 4 speed V2
2020 Sebring Orange Vette
1979 Chevy Boogie Hippie Van
Re: Help with hood adjustment [Re: derekeh] #761943
08/01/10 10:31 AM
08/01/10 10:31 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Before you go out buying hinges,...if just one side was lifting, maybe,...but if your like most guys, your just cranking the hood open all the way and trying to drop the hinges all the way down in the back on the adjustment bolts in an effort to lower the hood,....try the opposite first, open the hood, drop the front portion of the hinge down about halfway, tighten, let the hood's weight come down some to raise the rear adjustment slots upward, tighten, test, see if this heps, if it dose, then you are going in the right direction,...sounds crazy but you'd be surprised it works in many cases
