Re: Winston Cup (or GN) rear suspension question
[Re: AndyF]
#760961
07/29/10 07:53 PM
07/29/10 07:53 PM
Late '60's is when Junior Johnson started using the truck arms on Ford applications and they were mandated across the board shortly thereafter. Not sure of the exact year.
[Re: AndyF]
#760968
07/30/10 01:37 AM
07/30/10 01:37 AM
Posts: 27,474 So Cal
autoxcuda
So Cal
Here is another GN era car. This one is a little different but roughly the same era. This car has the K frame moved up into the frame and welded in place.
Hey, I've seen that before. Nothing like picking up a possible wing car for under $3K.
Seller advertised it as a kit car. IIRC, I yanked the buyer out of his swap spot to check this cool car out. Later I heard he bought it and drug it home.
[Re: AndyF]
#760969
07/30/10 01:51 AM
07/30/10 01:51 AM
autoxcuda
So Cal
Anyone know when the Mopar cars switched from leaf springs to trailing arm rear suspension? I took some pictures of an older Grand National (maybe a Winston Cup) car this week and it still had leaf springs in it. The car is probably from the late 60's or early 70's.
K frame car with torsion bars, Mopar power steering, etc. Obviously a factory frame car but heavily modified. The drive side torsion bar had a jack on it that could be adjusted by the driver to change the preload. Production lower control arms, drum brakes, tubular upper control arms, spline type anti-sway bar, etc. Pretty cool stuff to look at but the rear leaf springs surprised me. I just thought everyone had gone with the pickup truck type suspension back in the 60's.
I really don't think any Mopar GN cars ran trailing arms. Even the last Arrington cars. I'd ask Aero426 (Doug Schleinger)
The 1974 Petty Catalog shows leafs and T-bars. His last Charger in 1976 had leafs. The Petty Magnum had leafs.
In Stock Car Racing It said he ran 8 3/4 rear ends adapted to the Chevy Monte Carlos truck arm cars he ran after he stopped running the Dodge Magnums. Just to use up the 100's of gearsets and parts he had on hand.
#760970
07/30/10 04:04 AM
07/30/10 04:04 AM
autoxcuda
So Cal
No. Petty ran leafs on his last Mopar in 78.
[Re: autoxcuda]
#760971
07/30/10 11:23 PM
07/30/10 11:23 PM
Posts: 972 Mooresville, NC
A70Runner
Mooresville, NC
I am restoring a Jimmy Means 1976 Laguna stock car (Started as a older 73-74 Monte Carlo/Chevelle Old #12 car which is pretty Ironic considering I work on the 12 car now) Anyway...It has a truck arm susspention. I think back then it was all by who built the chassis. Who's car was it? Looks petty blue or Marcis blue hard to tell in the pictures.
"People Think I'm Insane Because I Am Frowning All The Time" Black Sabbath
[Re: A70Runner]
#760972
07/31/10 01:01 PM
07/31/10 01:01 PM
Posts: 2,129 Vermont
TrWaters
Vermont
The Chrysler kit cars of the late 70's all used torsion bars and leafs.
TR Waters
[Re: '72CudaRacer]
#760973
12/31/14 05:12 PM
12/31/14 05:12 PM
Posts: 113 s.e. MI
odcics2
s.e. MI
One of the funniest comments about those cars came from Buddy Baker a while back. He was ask how did he think the car that he set the closed course speed record with (now in the museum at Talladega) would do with todays knowledge, tires ect. His remark- "back then (1970) those cars were top shelf equipment. I look at that car in the museum now, and I wouldn't climb out of the electric chair to drive it today". My, how far they've come in 40 years
Thought everyone knew the real #88 is in Detroit, being restored...
check this out!! https://www.youtube.com/watch?v=vdwhM5xB-8Y
turn up the sound!
