Ground Cable Location please??? #760792
07/29/10 02:22 PM
07/29/10 02:22 PM
Roswell, GA - near Atlanta
cloneguy Offline OP
super street
cloneguy  Offline OP
super street
Hi all. We're nearly done with the 70 Cuda. Many explanations and photos to follow.
This part got removed but it missed the tagging and bagging phase of the project.
For anyone who doesn't know the car, it's a U code 440, 4 speed track pack car.
Please tell us where this goes.
Martin, GA Quality Auto Restoration with Fair FIXED Pricing. Fast-N-Dangerous@comcast.net
Re: Ground Cable Location please??? [Re: cloneguy] #760793
07/29/10 03:35 PM
07/29/10 03:35 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
That doesn't look like a factory part, at least I've never seen one look like that , what guage is that cable ?
Re: Ground Cable Location please??? [Re: JohnRR] #760794
07/29/10 04:06 PM
07/29/10 04:06 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The 1970 negative battery cables have two leads, the fat one goes to the driver's side head & the thin one to the radiator support.
You can toss that one in the scrap pile.
Re: Ground Cable Location please??? [Re: cloneguy] #760795
07/29/10 05:10 PM
07/29/10 05:10 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
trash can
Re: Ground Cable Location please??? [Re: cloneguy] #760796
07/29/10 05:22 PM
07/29/10 05:22 PM
cloneguy Offline OP
super street
cloneguy  Offline OP
super street
Thank You, Thank You, Thank You !!!!!
Re: Ground Cable Location please??? [Re: cloneguy] #760797
07/29/10 06:30 PM
07/29/10 06:30 PM
Long Island, NY
70plymA34 Offline
70plymA34  Offline
Long Island, NY
Its my car and I know where it goes,LOL.. Goes from frame rail to the closest bolt on bellhousing. Either way great job so far, look forward to seeing it.....
Re: Ground Cable Location please??? [Re: 70plymA34] #760798
07/30/10 08:49 AM
07/30/10 08:49 AM
JohnRR Offline
JohnRR  Offline
Someone ADDED it that is not factory , guess the car had the battery relocated to the trunk or the negative cable got changed at one point and it lost it's connection to the body .
Re: Ground Cable Location please??? [Re: JohnRR] #760799
07/30/10 11:19 AM
07/30/10 11:19 AM
Long Island, NY
70plymA34 Offline
70plymA34  Offline
Long Island, NY
no, that cable goes from the front frame rail on passenger side and grounds to one of the bellhousing bolts. thats from what my pics show. had nothing to do with the negative battery cable.
please correct me if I am wrong.
it never lost its connection to the body. it was unbolted when we were removing the engine and trans. i hope this helps
Re: Ground Cable Location please??? [Re: 70plymA34] #760800
07/30/10 01:17 PM
07/30/10 01:17 PM
colorado
a12superbee Offline
a12superbee  Offline
colorado
What they are saying is, yes you may have taken it off the front frame rail but it didn't come that way from the factory.
Someone had to have added it over the years for some reason.
I can't afford this. mark
Re: Ground Cable Location please??? [Re: a12superbee] #760801
07/30/10 01:33 PM
07/30/10 01:33 PM
JohnRR Offline
JohnRR  Offline
What he said , that was added for any number of reasons , since I didn't see the car before it was disassembled I , or anyone else , can only SPECULATE why it was added, it's not a factory installed part.
If the car gets a factory Negative battery cable it's not needed, though it will carry more current than the factory sized lead.
Re: Ground Cable Location please??? [Re: JohnRR] #760802
07/31/10 12:34 AM
07/31/10 12:34 AM
Long Island, NY
70plymA34 Offline
70plymA34  Offline
Long Island, NY
ok, that sums it up then, thanks
