Garage Hoist #75985
06/19/08 01:51 PM
06/19/08 01:51 PM
The Motor City
Stew4706 Offline OP
Stew4706  Offline OP
The Motor City
Hey Guys, I am looking at getting a hoist for my garage and I have looked at Rotary, Bend Pak, Backyard Buddy and a dozen more. Do you have any suggestions on brand and 2 post Vs 4 post??
Thanks!!
Re: Garage Hoist [Re: Stew4706] #75986
06/19/08 02:26 PM
06/19/08 02:26 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
well a 2 post is better if you plan on doing much front end work or differential work a drive on 4 post is much easyier you just drive on we have both here at work all ours are Roatry and a brand called Forawrd.If you get a 2 post I would recommened a clear floor asametrical.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Garage Hoist [Re: dusturbd340W5] #75987
06/19/08 02:37 PM
06/19/08 02:37 PM
Indiana
Cuda_Mike Offline
Cuda_Mike  Offline
Indiana
My Bend-Pac extra wide asymmetrical raises about 5 inches higher than the others when I bought it, about 11 years ago...
Re: Garage Hoist [Re: Stew4706] #75988
06/19/08 03:02 PM
06/19/08 03:02 PM
Central Ohio
Ledman_70 Offline
Ledman_70  Offline
Central Ohio
Go to www.garagejournal.com and look thru the forums. There was a discussion a few months ago about lifts. There's a LOT of stuff on that website.
Jeff Adams 64 426 Polara
Re: Garage Hoist [Re: Ledman_70] #75989
06/19/08 07:58 PM
06/19/08 07:58 PM
Middletown , Ohio
DonnieLawson Offline
Middletown , Ohio
I got the Bend Pak from ASEdeals.com , the 4 post 9000 lb extra large one , Its very well built and no problems with it and Ive had it about 2 years . I store my Cuda on it with another car under it , I also got a bridge jack which is killer when working on suspension parts , etc .
The only time I wish I had a 2 post lift is when I get ready to put the engine , tranny and K member in together from underneath
If you need storage space to double stack the cars , I think you would like the 4 post better
I have 12' ceilings and that works good , 14' would be better
