Aluminum vs. steel deep 727 pan #759818
07/27/10 10:40 PM
07/27/10 10:40 PM
East Coast, NJ
fig426 Offline OP
fig426  Offline OP
East Coast, NJ
Does a cast aluminum deep pan make the transmission any "stiffer" than a deep steel pan? I need to buy a pan and was wondering if it's worth the extra $100 for the aluminum. Thanks
Chris from New Jersey
Re: Aluminum vs. steel deep 727 pan [Re: fig426] #759819
07/27/10 10:45 PM
07/27/10 10:45 PM
Florida STAYcation
BeEtLeJuIcE ! Offline
The village idiot's idiot
Florida STAYcation
An Xtra hun ?
I like DEEPER alum pan ...since I run the ATF level on the lower side.
Re: Aluminum vs. steel deep 727 pan [Re: fig426] #759820
07/27/10 10:46 PM
07/27/10 10:46 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
without doing structural testing i'd say the alloy pan would definatly make the housing stronger plus the fact most alloy pans have ribbing on the outside, they would definatly dissipate the heat quicker.
Re: Aluminum vs. steel deep 727 pan [Re: fig426] #759821
07/27/10 10:57 PM
07/27/10 10:57 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I run the steel deep pan... never broke a housing yet
Re: Aluminum vs. steel deep 727 pan [Re: rebel] #759822
07/27/10 10:59 PM
07/27/10 10:59 PM
Locomotion Offline
Locomotion  Offline
I just bought the Summit aluminum version for a 904 mainly for the slight extra heat disappation. It came with an aluminum billet spacer instead of the brazed metal version with 3 screw tubes.
Check Summit for their brand and others.
I'm sure the thicker cast aluminum is stiffer than the stamped sheetmetal version also.
Re: Aluminum vs. steel deep 727 pan [Re: Locomotion] #759823
07/27/10 11:15 PM
07/27/10 11:15 PM
az
stage3 Offline
stage3  Offline
az
I'd want to get a cast aluminum pan for my 904, but can only find them with drain coming out bottom of pan. Would like to find one with drain coming out the back. Have tried most suppliers and the only one I can find is a fabricated pan which I have but it leaks. Any ideas? Thanks, Rick
Re: Aluminum vs. steel deep 727 pan [Re: stage3] #759824
07/28/10 12:08 PM
07/28/10 12:08 PM
Locomotion Offline
Locomotion  Offline
Mopar Performance has a cast aluminum 904 pan with a side drain plug - P5007794AB, but it costs almost twice as much as the Summit version - SME-1010R!
Re: Aluminum vs. steel deep 727 pan [Re: Locomotion] #759825
08/05/10 11:01 AM
08/05/10 11:01 AM
East Coast, NJ
fig426 Offline OP
fig426  Offline OP
East Coast, NJ
Ordered the B&M aluminum deep pan. It's nice. $129. Even has a hole for a temp sensor already and came with the extension and filter. Trying to get this car done for Missouri. Getting close.
Re: Aluminum vs. steel deep 727 pan [Re: fig426] #759826
08/05/10 05:22 PM
08/05/10 05:22 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i had a B&M deep pan in mine but had to take it out as it's REAL deep. too deep for my lowered junk, i have a TCI unit in now.
