I have an MSD distributor, which has the HEI sorta style connectors for the plug wires, and coil wire. The MSD blaster 2 coil has the socket style connection for the coil wire.
My coil wire has the HEI type on both ends.
Seems I remember a while ago seeing a "changeover" or conversion part that pushed into the top of the coil (socket end), but left a HEI type terminal sticking up so you could use this type of wire.
I can't find it in MSD's catalogue, or summit's site.
Are these available, or did I dream this
codfish
