Neutral safety switch for 1964 big block trans. #758679
07/26/10 07:12 PM
07/26/10 07:12 PM
6T4 Polara Offline OP
I need to replace the switch on my 1964 console shifted big block 727 transmission.Question is where to get one and are they the same for push button and console shifted cars.
John
Re: Neutral safety switch for 1964 big block trans. [Re: 6T4 Polara] #758680
07/26/10 09:28 PM
07/26/10 09:28 PM
New England
Tech Instructor Offline
New England
I know A&A trans has them.I think they are the same.I might have a used one I will check and see.
Re: Neutral safety switch for 1964 big block trans. [Re: Tech Instructor] #758681
07/26/10 09:58 PM
07/26/10 09:58 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
did you happen to look in MOPARTS.COM for sale section, transmission and drive train?
Re: Neutral safety switch for 1964 big block trans. [Re: Joesixpack] #758682
07/26/10 10:00 PM
07/26/10 10:00 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
Neutral Safety Switch, New,Made in USA...brands avail, Niehoff,Standard,Motorcraft&Holley,all look the same as pictured, will fit:
1955-1964 Chrysler(NOT 1964 FLOOR SHIFTER CARS_)
1955-1961 DeSoto
1955-1964(NOT 1964 FLOOR SHIFT CARS) Dodge and Plymouth
1960-1964 Valiant
1955-1964 Dodge Truck, w/Loadlite
$25each
w.cowger@comcast.net
sat july 10 2010
Re: Neutral safety switch for 1964 big block trans. [Re: Joesixpack] #758683
07/27/10 06:25 AM
07/27/10 06:25 AM
I need one for a console shifted car you have two switchs listed which is correct.Mopar part number 2889472 is the one I need.
JOhn
Re: Neutral safety switch for 1964 big block trans. [Re: 6T4 Polara] #758684
07/27/10 09:39 AM
07/27/10 09:39 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
JOhn
Actually,64/65 console shift uses this one.
Re: Neutral safety switch for 1964 big block trans. [Re: 62maxwgn] #758685
07/27/10 04:14 PM
07/27/10 04:14 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
thanks for that info I corrected my two ads, 1964 cars with a FLOOR SHIFTER use the later(1965-1968) NSSW, #2495537,2586994 or 2889472 all interchange and supercede each other.
Re: Neutral safety switch for 1964 big block trans. [Re: Joesixpack] #758686
07/27/10 05:00 PM
07/27/10 05:00 PM
Thanks all for the info.
Joe sent you an email.
John
Re: Neutral safety switch for 1964 big block trans. [Re: Joesixpack] #758687
07/27/10 09:57 PM
07/27/10 09:57 PM
Kenosha, WI wi/il border
BobN Offline
BobN  Offline
What about a nuetral safety switch for 1968 727 ?
Anyone make them still?
looka similar to this one pin type on this post.
Re: Neutral safety switch for 1964 big block trans. [Re: BobN] #758688
07/28/10 01:24 PM
07/28/10 01:24 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
as seen in MOPARTS.COM transmission parts for sale
Neutral Safety Switch Nos#2889472 AAUJ,, SUPERCEDES 2495537&2586994FITS;
1964-FLOOR SHIFT ONLY )1965-1966-1967-1968 SINGLE PRONG ONLY Chrysler
1964-FLOOR SHIFT ONLY)1965-1966-1967-1968 SINGLE PRONG ONLY Dodge
1964-FLOOR SHIFTER ONLY)-1965-1966-1967-1968 SINGLE PRONG ONLY Plymouth
$35.00
Re: Neutral safety switch for 1964 big block trans. [Re: Joesixpack] #758689
07/28/10 02:52 PM
07/28/10 02:52 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Just to pick nits....the 1968-all isn't correct either, the 3-prong switch was introduced in the middle of May '68.
Re: Neutral safety switch for 1964 big block trans. [Re: John_Kunkel] #758690
07/28/10 04:14 PM
07/28/10 04:14 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
Thanks ad has been corrected
Re: Neutral safety switch for 1964 big block trans. [Re: Joesixpack] #758691
07/28/10 09:32 PM
07/28/10 09:32 PM
BobN Offline
BobN  Offline
What about for column shifted 68?
Re: Neutral safety switch for 1964 big block trans. [Re: BobN] #758692
07/29/10 02:20 PM
07/29/10 02:20 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
'64 is the only year that the floor shift used a different NSS, from '65-on the NSS was the same regardless of the type of shifter.
