1968 dodge coronet factory air car
#757100
07/24/10 11:30 PM
07/24/10 11:30 PM
Posts: 1,639 Brandon, Ms
cornet684me
Brandon, Ms
i have a 1968 dodge coronet factory air car, i do not want to use all the out dated old stuff, i want to put all new, i have taken the p/s off the car and i have found a air compressor bracket that will fit where the p/s unit hooked up, is anybody running this set up? i have found all new stuff from here http://www.bouchillonperformance.com/BPE4705.aspwhat is your take on this set, they sell all you need to hook the factory air up on the car.
Re: 1968 dodge coronet factory air car
[Re: mopowergtx]
#757106
07/25/10 02:02 AM
07/25/10 02:02 AM
Andrewh
as with most kits, it is 2 parts. you can have all new under hood, or all new under dash, or both. most fittings are standard, so you can mix and match. They recommend if your condenser is in good shape and evap, reuse them, but get a new dryer.
If you want your underdash fixed up, they restore them as well, so you can reuse your old setup underdash, and the new setup under hood.
